Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Wega Blinking Standby Light
My TV will not turn on and the stand by light is blinking 7 times, which I found out means exceeded high voltage and says to check power supply regulation & horizontal circuits. What does this mean? All of a sudden this happened. Please help!
  • 2 more comments
  • reber61 Jan 05, 2008
    similar problem in that when I try to turn set on, the blinking red "timer/standby" light comes on and not the picture. Difference is that the set will on rare occasions turn on and operate properly, but if I turn it off, the next time it goes back to blinking. Also, it seems to turn on only in the morning. Because I can turn it on occasionally, I have tried to set it back to factory settings and made sure it is not on timer or anything else. The problem persists.
  • MikeLight Jan 05, 2008
    I'm having the exact same problem with a KV-34HS510!  Find any solution?
  • SicaB75 Jan 06, 2008
    same here....we got it to come back on and now we haven't turned it off. We just leave it on 24 hours a day too!
  • cdennis Jan 09, 2008
    My TV will not come on but the stand by light will blink. It will turn on, then shut right back off immediately. Any suggestions?
No... we got it to come back on and now we havent tuned it off since... we just leave it on 24 hours a day!
Posted on Jan 06, 2008
Sony trinitron kd-34xs955 standby light is blinking 7 times
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
As you can see here, seven blinks of standby light is due to some over voltate at the final anode of the picture tube. This is a protection process that going on insde the tV circuits, to prevent more damage to other comnponents on board. The most common cause for this is with the main power regulator out voltage itself. If any way, it ahs exceeded 135VDC, this kind of fault will occur. Check the main power regulator section circuit for any damaged component/s. Replace all the small electrolytic capacitors there. Visit the site named 'Electro-help' for more details. Check this LINK and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy. Some times, the ads attached with each posts might help you to find the availability of spare parts. There are more than 550 posts to different brand TVs. Blinking codes and details are there.
Aug 09, 2012 | Sony FD Trinitron KD-34XS955 34" TV
I have a sony wega trinitron, when the tv is turned on, (no visual, or sound) the red stand by light blinks 7 times, and you hear the tv click off? Please help
Jun 06, 2011 | Sony FD Trinitron WEGA KV-36FS120 36" TV
The tv standby light blinks 7 times then repeats. What do I do?
Dear John,
Welcome to Fixya
Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits. I think it helps
Chandrashekhar
Dec 27, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Stand by light blinking 7 times. occassionally turns on when pressing reset and power button.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
There is a High Voltage fault or power supply fault.
Hope that helps.
Dec 09, 2010 | Sony FD Trinitron WEGA KV-30XBR910 30" TV
Standby light blinks 7 times and tv will not turn on
Thanks for using FixYa. Standby light blinking 7 times means high voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. You’ll need to check power supply regulation and horizontal circuits. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Mar 12, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
The standby botton blink 7 in my sony trinitron
May 07, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony wega kv-36hs20 will not turn on
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Mar 02, 2009 | Sony FD Trinitron WEGA KV-36HS20 36" TV
Stand by light blinks 6 times, wont power on
Here you find sony blinking codes
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206.
Aug 10, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
TV will not come on.
The 7 blinks indicate a high voltage shutdown (high voltage exceeded 33,000V). This is usually caused by a defective regulator. Could you please post the exact model number (KVxxx) and I'll look up the part you will likely need?
Thanks,
Dan
Jul 28, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony Triniton Wega Model KV 32HS510. After pushing the power button,the tv starts to power up, then the standby light blinks 7 times then pauses before blinking 7 times again. It continues to do this,...
This is usually an indication of a failure in the scan amplifier sections. When the scan amplifiers or high voltage sections fail, the main power supply will usually also require servicing.
It is very common that the fly-back and high voltage multiplier and also the horizontal output stage fails in these sets. Along with it, the power supply will usually require to be serviced. On rare occasions, the vertical deflection amp fails.
Jerry G.
Jul 08, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
269 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
