Question about Panasonic DMR-EZ47V DVD Recorder/VCR
Error code F04
Unit set to record daily program on vhs get error F04 when it turns on ,also when I set a program to tape on the scheduler the unit doesn't even turn on
  • 1 more comment
  • charlita Jan 12, 2008
    I don't have the error code, but I do have the problem of the machine not coming on and recording when it is scheduled to do so. When I look at the scheduling after, the programming is greyed out with no explanation as to why it did not record.
  • Anonymous Apr 06, 2008
    Video casetera Panasonic muestra error F04 y no sale la cinta. Tampoco deja hacer ninguna otra operacion.
  • floydco Dec 18, 2008
    unit gets error code F04 when it attempts to read either the DVD or tape and neither will eject. I believe it is missing a voltage which might be 12 volts. I can't find a maintenance manual so that I can locate the problem.
  • 4402 Answers
SOURCE: Sony SLV-D300P DVD/VHS Player Tape Eject Problem
no reset, the infred led inside the unit are bad and need to be replaced common problem, they are located on the ends of the tape mech.
Posted on Dec 04, 2007
  • 3 Answers
SOURCE: error code u80
Take It To A Repair Shop And Let Them Put In A Security Code Or Look Through The Manual
Posted on Feb 01, 2008
  • 284 Answers
SOURCE: VHS Tape stuck and won't eject
you going to have to open it up and remove the tape manually, either the belt drive is broken or gears are.
you going to have to get your hands dirty. :)
Posted on Jun 25, 2008
  • 2785 Answers
SOURCE: I was transferring a
plz try by using a dvd lens cleaner, if the problem is not solved then try by changing the dvd data cable, if the problem is not solved, try by reinstalling the burning software if every thing fails then you have to buy a new dvd rom
Posted on Jul 08, 2008
SOURCE: I have a Samsung DVD -VR 357 combo unit and i can't record
I have the Samsung dvd-vr 357. I have had a couple problems with it but I called samsung and they walked me through fixing it each time. I don't know if you have tried this or not but that is my suggestion. The last problem I had was copying from vcr to dvd. I got audio but no video. Problem was it was on dvd when i started it, it should have been on vrc. It should be set on whichever one you are recording from. Hope this helps someone.
Posted on Jan 10, 2009
You seem to have a K-mech model. If this is the case f04 means that the mechanism locks unloading. The cause being something to do with the loading motor.
Feb 10, 2014 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Panasonic Model No. DMR-ES35V DVD Recorder error message H02
check it out this link, maybe can help you
Try to clean reading head from vhs player with isopropilic alcohol, maybe is dirt and give this error.
Good luck !
Dec 03, 2017 | Panasonic Dmr-es35vs DVD Recorder / Vcr...
VHS tape is stuck in the VCR. Tape will not eject, will not play or foward/rewind. The unit has been working just fine with no problems. The VHS tape has been inserted into the machine to record daily...
assuming you have power to the machine , i would suggest the ejection drive belt has stretched , 2 choices here , take it somewhere and get it fixed or unplug it from power supply and remove the top casing yourself and have a look.
Jan 29, 2018 | Toshiba SD-V291 DVD Player/VCR
Sony SLV-D100 DVD/VCR unit won't record on a VHS tape.
Check the tab on the VHS tape be sure it is there. If not place a [piece of transparent tape on it to simulate the tab and try again.
Oct 02, 2017 | Sony SLV-D100 DVD Player/VCR
Panasonic DMR-EZ47V Error Code F03
I saw this same issue. I would unplug and plug in the DVD and it would still show error code F03.
It turns out that one of my kids had shoved a couple of small objects inside the VHS opening and it was blocking the operation. I removed the objects and it works fine.
This error code is not listed in the manual that came with the DVD player.
Dec 21, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Timer Recording
To schedule a weekly or Mon-Fri program on the DVD scroll back in the "date" box (instead of forward to a future date. You will have options for once a week or Mon-Fri.
Jul 27, 2008 | Panasonic DMR-E75V DVD Player/VCR
Recording a tv show on a emerson vhs recorded problem
Allow the VCR to perform the much needed channel set up process... after this procedure, you will be able to record error-free...
May 30, 2008 | Emerson EWV403 VHS VCR
Cannot Record using VHS
The question here would be one of two things. Obviously without probing further it would seem you're having an "unusual scheduled recording" issue. But, without further information it's difficult to tell.
For one, are you recording from straight signal (cable or antenna into the RF IN of the unit), or are you recording from a box (cable or satellite receiver or D/A converter, etc)?
Do your scheduled recordings record the first and not even pick-up the second, or do they record but only record static?
These are questions that will need to be answered before further assistance can be provided.
Feb 20, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
VHS player stops
VCR is set with blank tape..Bring up vcr control on TV with television set on Chanel #3, go to menu
Follows procedure for progamming date,time start,time finish,chanel and.speed and single recording.finally click on menu and turn vcr off. Vcr lights indicate set for taping,,.Does no start to tape at requested time and lights indication taping ready stays on ??????
Aug 22, 2007 | Zenith DVR413 DVD Recorder/VCR
Error F04 message displayed
Panasonic K deck F03 or F04 shows in display check loading motor coupling pt no VDP1434 or motor pt no VID12128 £11.95 CHS
Nov 22, 2006 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
262 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
