Texas Instruments Voyage 200 Calculator
Blank vertical lines are appearing on the screen.
shared by 6 users
posted by Fadd on Jan 04, 2008
My texas instruments voyage 200 was perfect the year i used..
then suddently i saw 2 vertical blank lines appearing on my screen..
after one more year, i have around 30 blank lines that are hiding what i write on it.
ANY HELP TO TAKE THEM OFF??
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
5 Other Users Have The Same Problem
Posted by Melon00 on Oct 23, 2008
Mine has the verticle lines as well. They appear on and off in different spots. I talked to TI, and they wanted like $100 to fix it. I went to Radio Shack, and they wanted like $120 to fix it. I would like to know if there is a simple solution to this issue, such as cleaning or re-soldering it.
Posted by Marvin Ray B on Oct 18, 2008
I have two voyage 200's they both have those lines too.
Posted by Guest on Jun 28, 2008
vertical lines on the screen
Posted by duca_87 on Jan 08, 2008
I also have about 10 blank lines on the screen. I beleive it is a loose connection, becuase at different occurances, different lines are missing. If I push a little on the screen, sometimes they reappear. (Maybe some ribbon cable?)
Posted by Guest on Jan 07, 2008
there are lines on my ti89 that block the stuffs i input.
Best Solution
posted on Mar 25, 2008
Helpful (85)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
**** it
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Blank vertical lines are appearing on the screen.:
I don't want to Accept this solution
Can you Help with these Calculators problems?
Calculators
i'm having trouble programing my store name and phone...
Calculators
Hi!!!! in the month of Aug'08 I changed my job, previous I...
Calculators
I wondered if you could tell me how to change the tax rate...
There are blank lines 1 pixal wide going horizontal and...
When I press the "On" Button, the calculator...
Loading problems.
Repair Service
Find Calculator Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
