Question about Whirlpool GHW9400 Front Load Washer
Whirlpool washing machine model GHW9460PWO, error code 11F
I researched and found that this is a communications error between the CCU and MCU. I have have cleaned all connector contacts on these two units but intermittent problem still exist. It may wash 5 loads fine then mess up on the next two. I have run the diagnostic check and that runs okay. Should I replace the CCU next?
  • 447 Answers
Yes it may be in the MCU but I had one do this and it was in the CCU. Has it ever thrown a Fdl ??? Door lock code?? Thats another sign its in the CCU
Posted on Jan 04, 2008
    Problem Solver:
  • 19 Answers
Looks like I may have been going in this direction. Check out what happen to me on this link. I hope this could be of help! http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
Posted on Jan 26, 2008
What is the f11 code?
the code is for Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
repair:
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
  • MCU (motor control unit ) found next motor CCU found on top of unit under maun cover.
  • Mar 10, 2011 | Kenmore Elite 45986 Front Load Washer
    Our whirlpool elite washer keeps F11 erroring and FDL locking the door.
    Hi.
    FDL is door lock. This is the first part to be tested, since it can be symptom of a wiring problem.
    The door lock is tested by reading impedance on the door latch contacts.
    If the door lock is OK, do the following troubleshooting for F11. The problem is usually CCU.
    F11 is communication error between CCU (main control unit) and MCU (motor control unit - additional control module connected to motor and to CCU, located in a sealed box inside the washer).
    This usually means that either CCU or MCU is defective. In some case the connectors or the wiring harness connecting the two modules is the problem.
    The tech sheet says:
    F11:Serial Communication Error
    Solution:
    * Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
    * Check the Drive system for any worn or failed components
    * Check MCU
    * Check CCU
    * Check Motor
    The wiring harness is tested using a multimeter to ensure that there is continuity between the MCU and CCU connectors. If a single wire is good it will read zero Ohms (closed) from contact to contact.
    Motor is tested reading Ohms, it must be read about 6 Ohms on three different pairs of contacts.
    Drive system in motor is checked observing if any of the parts are broken.
    MCU and CCU are tested reading volts during operation and testing at component level. The testing must be done by a tech. Check CCU to see if there is any sign of failure (eg burnt spots).
    Most of the time the problem is CCU. Trick to repair it include testing and eventually reheating the solder joint of the two on-board relays, cleaning connector contacts with circuit cleaner solution. This in case that the problem is CCU.
    Disconnect the unit from power for five minutes as first test. This will reset CCU.
    Jan 20, 2011 | Kenmore Elite 45986 Front Load Washer
    Whirlpool 9400 frontload washer displaying F11 code. Is there a diagnostic that I can run?
    Hi.
    Solution:
    * Check MCU
    * Check CCU
    * Check Motor
    The diagnostic is different depending on the model. The diagnostic is illustrated in the machine tech sheet, which is tucked inside the control panel assembly. Open control assembly and check. By the way, if you have f11 the diagnostic won't help. Machine must be tested.
    Regards.
    Ginko.
    Jan 17, 2011 | Whirlpool WFW9400S
    My Whirlpool GHW9100L was tripping out with a F11 error during the rinse/spin cycle as the unit was ramping up to spin speed with a small load in the wash bin. I reset the unit several times after...
    Hi.
    In your case the problem is more likely a worn connector or a defective board.
    Solution:
    * Check MCU
    * Check CCU
    * Check Motor
    Dec 15, 2010 | Whirlpool GHW9100L Front Load Washer
    Washer displays an F11 error code. I replaced the MCU but still the F11 code. Wire harness is good.
    Hi.
    It is probably the CCU (main control). Wiring harness, motor and drive train must be checked before replacing the CCU.
    Here full troubleshooting for F11.
    Solution:
    * Check MCU
    * Check CCU
    * Check Motor
    Nov 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    CODE 11F WHEN START. TYPE HE3
    F11 is a serial communication error. Could be as simple as a loose or faulty wire harness, bad drive component or more complex like a failed MCU, CCU or even the motor.
    Nov 20, 2010 | Washing Machines
    Trouble code f11 or fdl for whirlpool duet front load wash machine.
    Hi.
    Solution:
    * Check MCU
    * Check CCU
    * Check Motor
    Nov 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    My whirlpool Duet washer keeps stopping in the middle of a cycle with the code F11. It doesn't go through the spin cycle. Any suggestions? Thanks!
    Hi.
    Solution:
    * Check MCU
    * Check CCU
    * Check Motor
    Oct 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    My washer keeps shutting off and flashing 11F
    serial communication error communication between the central control unit and the motorunit cannot be sent correctly
    check wire harness connections to the MCU, the motor,and the CCU
    check the drive system for any worn or failed components
    check MCU
    check motor
    check wire harness
    Apr 30, 2010 | Kenmore Elite 45986 Front Load Washer
    How to fix f28 error on my whirlpool frontloader washer
    Hi, Here is what the manufacture says about this error code and my comments will follow. SERIAL COMMUNICATION ERROR The communication between the Central Control Unit (CCU) and theMotor Control Unit (MCU) cannot be sent correctly. Possible Causes/Procedure 1. Unplug washer or disconnect power. 2. Check wire harness connections to the MCU, the motor, and Central Control Unit (CCU). ? Check connections of the CCU board within the housing. ? Make sure all grounding switches are engaged. 3. Check that the serial harness at the MCU is not mounted upside down. The wires should be to the left when facing the MCU connectors. 4. Check the drive system for any worn or failed components. 5. Plug in washer or reconnect power. 6. Verify CCU operation by running a Diagnostic Test or any cycle This type of error is going to need the services of a factory trained service person. The trouble could be in multiple locations and hard to diagnois. Sorry to be the bearer of the bad news but this one is not a simple one
    Apr 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool GHW9400 Front Load Washer Logo
    503 people viewed this question
    Sal De
    Marvin
    Marvin
    Gerry Harvey
    Gerry Harvey
