Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Problem for Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Water floods out the from the bottom when filling
By kjsatx99 on Nov 04, 2009
water floods out the from the bottom when filling with soapy water and clean water when the rinnsing
Best Solution
posted on Nov 04, 2009
Very Helpful)
jsrock516
Rank: Guru  Whirlpool Washers & Dryers  Expert
Rating: 96%, 6826 votes
If this is a Whirlpool top loader you must remove the exterior washer case to access the internal components. Just follow these steps to access the interior to determine where the leak may be coming from:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
If the leak is coming from the front of the washer, most commonly this is caused by a leaking drain pump. The pump is located in the front directly below the wash tub. The pump is not serviceable and must be replaced if it is damaged.
Some other items to consider:
1. Check your fill hoses to ensure they are tight and not leaking. What can often appear as a washer problem, may be a loose hose.
2. With the washer case removed, check the area UNDER the wash tub. If the leak is coming from the center above the transmission, the tub seal may be leaking.
3. Inspect the wash tub for any cracks. If the tub is cracked and its not serious, you may be able to get by with some marine epoxy to reseal it. If the crack is significant, a new tub will be required.
4. If the water is gushing out of the bottom of the washer, check the air dome on the lower right hand side of the wash tub. This is a small plastic air hose that runs from the wash tub all the way to the pressure switch. If this hose comes loose, the washer will start to leak as it fills. Simply reattach if it comes loose.
NOTE: The ends on the air hose can become stretched over time. If you have enough slack in the hose, you can snip off a small portion of the end and reattach it to make sure it fits snug. If not, attach the hose to the air dome and place a zip tie around it where it connects to the air dome fitting. Make the zip tie snug enough to keep the hose from slipping off. Do not overtighten.
If you need an illustration of your washer and components, searspartsdirect.com, appliancepartspros.com, or pcappliancerepair.com usually have some excellent exploded view diagrams that you can refer to.
If you determine the pump is damaged and needs replaced, the following link explains how:
http://www.fixya.com/support/r397092-replacing_water_pump
Prices can vary between these sites so shop around for the best deal. NOTE: Use the part number from the Sears site and use it to "Search by Part Number" on the other sites. It makes it easier to find as some sites may not have your model number listed, but will still carry the part.
To reinstall the washer casing, follow these steps to ensure you get the case correctly placed and secure on the frame:
1. With the lid of the washer open, grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you. Reinsert the brass clips by placing the clips into the slot on the back of the washer first, and then forcefully push then down into the opening on top of the washer.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
Read through everything thoroughly before beginning any repairs. If you have any questions, or require additional assistance, please let me know. I hope this information is helpful.
NOTE: You can also order a repair manual for about $20 (part number 1170635) at repairclinic.com if you need more instruction.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" your help was extremely helpful once i found the screws in console it is the drain pump with a hole, front face between inlet and outlet many thanks " - kjsatx99
Popular Solutions for Whirlpool Ultimate Care II
Questions and Unsolved Problems for Whirlpool Ultimate Care II
Do you recommend Whirlpool Ultimate Care II LSQ9549L Top Load Washer?
Answer
Answer
how do I take the fabric softener dispenser apart to clean i. We just bought one used and I want to... (More)
Answer
my agitator on the washer is loose bobbles around when in use and when off i can turn it all around... (More)
Answer
it fills up and then makes small noise then wont do anything else
Answer
Whirlpool Ultimate Care II lsq8511kqc It started to wash OK, but when in the step for rinsing, it... (More)
Answer
My washer will not work to wash clothes, motor hums. Ity will work in Rinse mode.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Whirlpool Ultimate Care II...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14904
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
