Question about Sylvania 6427TE 27" TV
6427td im looking to get a new board for my tv the board that has the power bottons on it can anyone help
    Problem Solver:
  • 25 Answers
In order for a solution i would need the model of the tv located in the back....get back to me
Posted on Aug 30, 2008
6ya staff
SOURCE:
Power botton flashes but will not come on
my rca 52 projection tv started to shut off on its own
after some research I pulled the main board and replaced
three capacetors that looked suspect replaced board and tv
worked fine for 3 days and went out again any suggestion.
Aug 20, 2012 | RCA D52W135D 52 in. TV/DVD Combo
R56wh78 im having a problem.. the tv started the 3d effect so i replaced the convergence board.. and fixed the problem for about 2 days (convergence is still good).. now im having a new problem.. the tv...
The Deflection Power board is the the most likeliest cause of the dead set issue, and that could have also caused the prior issue of convergence board since the deflection board supplies all base voltages for the convergence circuits
Aug 16, 2011 | RCA Televison & Video
I have a problem with my lg 42pq30 plasma, it has vertical lines distortion across the screen. does anyone know how to fix this problem
yes is the 2 top & botton board connect to Y board control is bad need new one
Most problem on plasma TV is heat & burner some component, about 80% is 2 top & bottom board connect to Y board is come in bad
Feb 04, 2011 | LG 42PQ30 42 in. Plasma TV
Flashing power button tv won't turn on Nothing on screen does not respond to remote. Pressing and holding power button on tv does not work. Screen is black and power light just flashes. Tried unplugging....
yes call the tech and have the power board replaced. In future have the TV plugged into an anti surge board to protect it ( and you from expensive repair.) I suspect you will need a new power supply fitted
Please rate the help to keep us online
Aug 17, 2009 | Toshiba 42HP95 Television
Tv won't turn when you push power botton
What make,and model is your TV?Open the back of the TV,and look at the can shaped items on the boards.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
Nov 01, 2008 | Televison & Video
SVA PLASMA TV
I got this same tv from a guy in my area he would press the poewer botton on the tv and the standby light comes on and then turns off, so he gave me the tv for free i took the back panel off, and everytime i press the power botton the green light came on where the screen board is and went back off after i let the botton go i took the power board out took it to a repair shop to see if there was anything a wrong with it everything was good so i replaced the two fuses on the board and the one on the screen board, i had a feeling about the power switch so i jumped the wires on the switch purple to purple and green to green, I put it back together pluged it in the standby light came and stays on now, so i went out and got a universal remote for the sva at walmart for $15 programed it and pressto the tv works perfect so three fuses $3.60 two small pieces of wire and ele tape $0 my time 35 mins = one working plasma for $3.60 so when you have this problem like everyone else check the power botton switch, there cheap and check the fuses theres only three and if that dont work idk what to tell ya. and you do need a remote or tv wont work.
Aug 16, 2008 | SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready...
Screen problem
you might have damaged the mother board. im a game consol repair service owner and personal what i would do is go to ebay and buy a new power switch first of all this will cost you about 10.00 and that covers shipping. install it your self correctly put the console back together give it a nice 4-5 hour charge and see what happens. also u could try popping the battery out for a hour and put it back in. you might have damaged the mother board and if so you need to buy a new mother board which will cost you 90-110.
if the power botton is broken is could cause the system to power on and off and maybe even freeze. fix the power botton
May 18, 2008 | Sony PlayStation Portable (PSP) Console
Trutech tv model #PLV16260
Heres what mine did:no picture no sound, when i hit the remote the indicator light went out....piece of crap is six months old, cant find any info on it, cant get a hold of anyone at Trutech.
So i took it apart, on the board that the power cord is attached to, i found six blown capacitors. There is also a big ass one in the middle of that board which looked ok but blew out the bottom.I replaced them, and im watching it as i type.
Its fairly easy but if your not comfortable soldering on a cheap circuit board, take it to someone.
I hope it helps, i think this repair will fix the other Trutech models with the same problems.
Eric
[email protected]
Nov 22, 2007 | TruTech PLV16260 Television
Sylvania 6427TE 27" TV Logo
42 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
