Question about Panasonic Toughbook 71 Notebook
CF-71 battery LED always flashing
I have a fairly new battery for my fairly old CF-71. Last night after using it during the day, I noticed that the red battery LED started flashing. The computer died so I inserted the AC plug. The battery will not recharge. The LED flashes even when the battery is out of the notebook. The AC adapter is fine. The notebook operates when on AC, and the battery LED flashes. Is there something I can replace easily inside the computer. It is not worth more than a few hundred $$, but it still does fine for my application.
  • 233 Answers
I would say bad battery, batteries can short and just die, they usually get hot too, try a new batt. don't buy a new one if you can even find it as it will cost allot, what I do is I have a local battery store replace the internal batteries on the battery pack, there are also places online that can do that for a fair price
for example a DELL battery pack to purchase was $185 I had one rebuilt for $25
Posted on Jan 05, 2008
    Champion:
  • 238 Answers
Hi, first try cleaning all the contacts of the battery and the laptop,let me know
6ya staff
SOURCE:
Wheelchair runs fine after charging but only after 1 day 6hrs use it stops with a jerk and then controller lights start blinking.
Abdus,
Thank you for all the information, number one, charge with the joystick on for 12-14 hrs. there is a circuit in the joystick that can cause problems, in order to reset it you will need to charge it like this. The batteries will last longer if the batteries are charged every night that it is used during the day, also, instills good charging habits.
The blinking is a flash code, count the flashes, and refer to the owners manual for meaning. The joystick maybe failing or the controller or both. Motors may need to be cleaned out.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Apr 12, 2016 | Health & Beauty
Alarm went off but no smoke was found and no other smells were detected. I do not believe that there was CO present. All the units were activated. after a period of time they stopped. This occurred 3 times...
http://www.kidde.com/Documents/User-Guide-900-0102-A-ENG.pdf Remember that smoke take presidence over C/O detection so notice whats going off first . LED Indicator Operation
Red LED
The red LED will flash as described below under the following
conditions:
--During smoke or CO alarm, with every beep
--During testing (same as alarm)
--Low battery, single flash with chirp
--End of product life, double flash every 30 seconds with chirp
--Unit error mode, single flash with chirp
--Unit error mode, a Fault Code is flashed every 30 seconds (can
be observed and reported to customer service for
troubleshooting. Above is the user guide.
Sep 09, 2013 | Kidde 9000102 Night Hawk Combination...
Two red flashing led lights flashing. Constantly get the same problem fix and am tired of this problem had 4 controlers replaceded and several other things done almost $10,000 dollars done last year alone...
The 2 flashing red lights indicate a low battery. Did you have the batteries replaced? and did you have the charger checked? The charger could not be giving you a full charge or you didn't charge the batteries correctly. It takes about 9-10 charges to bring the batteries to 100% operating capacity. Always charge the batteries before using after installing new ones and then charge nightly when you sleep. When you get up in the morning the batteries should be fully charged and last all day. Never charge more than 12 hours and always store or put up fully charged Hope this helps and sorry that no one can seem to help you except spend your money needlessly
May 25, 2011 | Pride Mobility Products Jazzy 1170 XL Plus
I need the instruction manual. Also, what is the top red light for? Just what does it do
Hey, you got you self a Russian NV monocular. There should be two switches. One switch is to turn on/off the unit. The second switch is used to turn on the IR illuminate--which means infrared red light. To improve the night capabilities of the NV monocular. Ther are two LED's one green for on/off switch and one LED that is red for the IR illuminator.
NO-NO-NO's
When the NV monocular isn't been used, take the batteries out. The worst NO-NO's is looking through monocular during the daylight hours. The do have metal front lens cover with a small hole in the center for a few minutes of viewing during the day. Remember---Use Only During the Night---Do look at bright lights, don't let the kids play with it and make dam sure that Grandfather doesn't get his hand on it. He will be doing long range peeping at the neighbors or the lady that leaves here blinds open during the. Kid-No, Grandfathers-N0, Fathers-that up to them. If pop going some night look see. I'll make a bit his survival ratio has raised demise by 70%. stewbison
Feb 11, 2011 | Kalinka Cyclop 1-V (NZT-1M2) Wide Angle...
Latest eurovox codes
codes as of sat 13 mar 2010
cf 53 0c 33 79 61 71 85
52 5e 8d 45 fc 75 f6 4a
Mar 09, 2010 | Televison & Video
Starview telewest codes 21/01/2010
Telewest last updated 12/10/09
00 CF 53 OC 33 79 61 71 85
01 52 5E 8D 45 FC 75 F6 4A
NO CHANGES YET.
Jan 21, 2010 | StarTech.com StarView SV211K 2-port KVM...
Standby LED flashes red 4 times with pause then 4 times
You either have a bad fan or one of the rotation sensors mounted on one of the fans has failed. Take the back off the set and see it the main fan slightly right of center is rotating. If it is, there are two more fans, one mounted right above the lamp and another on the optical block itself. You will have to pull the optical block to check those.
Oct 25, 2008 | Sony KDF-E42A10 42 in. LCD Television
Ntl code
Teleshit code
00 75 4A 66 04 CF 7F 55 F3
01 71 72 88 94 62 BD 84 98 NEW
Jul 19, 2008 | StarTech.com StarView SV211K 2-port KVM...
Open Questions:
Outlook MAil Contact NuMbER {?}{1?.855?.536*?*5666}#[email protected] COLORADO call or contact SbCgLoBaL mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbCgLoBaL mAiL USA Calling SbCgLoBaL mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbCgLoBaL mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbCgLoBaL mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbCgLoBaL mAiL USA's phone numbers against each other. Contacting SbCgLoBaL mAiL USA in General WhileI:855:,:5365666 is SbCgLoBaL mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I:855:,:5365666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbCgLoBaL mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbCgLoBaL mAiL USA.
Nov 11, 2019 | Best Computers & Internet
Outlook MAil Toll {1^855^&536^&5666}#[email protected] Free NuMbER HELP DESK call or contact SbCgLoBaL mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbCgLoBaL mAiL USA Calling SbCgLoBaL mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbCgLoBaL mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbCgLoBaL mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbCgLoBaL mAiL USA's phone numbers against each other. Contacting SbCgLoBaL mAiL USA in General WhileI:855:,:5365666 is SbCgLoBaL mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I:855:,:5365666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbCgLoBaL mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbCgLoBaL mAiL USA.
See all Panasonic Toughbook 71 Notebook Questions
Panasonic Toughbook 71 Notebook Logo
310 people viewed this question
Top Panasonic Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
