The dampness sensor is just the two curved metal strips (about 5 inches long, and about an inch apart) located very close to the lint filter. (stick your head in the drum and look back down to your right) These strips can become coated with a waxy substance from fabric softener sheets which prevents them from detecting the moisture correctly. Just clean them off with a little soap solution.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for GE Profile Harmony DPGT750GC
I went through all the tests and the only test that did check out was the Ignightor, I ordered a new...
(More)
I went through all the tests and the only test that did check out was the Ignightor, I ordered a new one and it ran the DAY WILT TEST and when the cycle first starts it meets the TIN(target) temp of 430, and the TOUT(target) temp of 160 is met. About a minute after these temps are met, it cycles and cools. I have good blower speed and then it tries to warm up again to no avail. Also it acts this way no matter if I have the vent line connected or not, I did that test to see if there was an exhausting problem. There are no blocked lines and I also vacuumed the inside of the drier and it's cleaner then the day it was new. Any idea what might be the problem, or next thing to check. Thank you for your help in advance, Harry
My dryer is not heating and someone has said it is not heating element or the coils that send the...
(More)
My dryer is not heating and someone has said it is not heating element or the coils that send the information to the heating element inside. They said it was the computer board. How much does this part cost?
