Frigidaire Front Load Washer Problem
While washing towels, the washer stopped before the rinse cycle and started humming. It will not rinse now or do anything except hum. It won't let me reset the wash/spin cycles. Any suggestions? Thanks.
  • 1 more comment
  • Anonymous Mar 16, 2014
    It's a Frigidaire front-loading stackable. Gallery series
  • Anonymous Mar 27, 2014
    Indesit washer dryer 966w It will run all other cycles except a fast spin
  • Anonymous Mar 29, 2014
    but if you unplug and reset will rinse and spin in quick rinse cycle this washer is a hydrowave type
  • 1,294 Answers
Plug off the wall, open up the back to check your belt, might have come off. Place around motor pulley & turn the drum wheel to slip on the belt gently from either the right or left. If too loose you have to replace with new belt.
Rate if helped pl..................
Posted on Jan 04, 2008
How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin Read more: How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin |
Hello - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the door lock assembly or the timer and control board not communicating correctly. Contact a professional to move forward accurately.
Oct 21, 2012 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire affinity front load washer
If the unit will not spin at all and makes a humming noise, sounds like something has seized up in the back of the unit. This could be a belt broken, motor seized up, or the transmission, if your unit has one, is gone.
Jul 17, 2012 | Frigidaire ATF6000ES Front Load Washer
Washer will go thru the wash but always stops at
ck the cold water is on / ck the water valve . this would stop it in cycle . it can't get rinse water . maybe pc control but
Dec 03, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer runs until rinse cycle, then starts making
pull problem code from machine. give knob a turn to wake machine-wait 5 seconds-then hold down start and cancel buttons at the same time. Your problem code will come up.
Nov 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer will not start washing cycle. Machine hums like the dryer
Check the drain for clog. If the drain is dirty, the washer won't fill, rinse, or drain.
May 23, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Frigidaire front loading washer stopped at rinse cycle. 3 beeps
When in doubt check the easiest thing to check. The pump can cause a number of errors to come up. Since the unit stopped in rinse I would start but checking to make sure there is nothing obstructing the pump before going to the expensive parts.
Feb 22, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front washer has power but won't fill up, drain or go through correct cycles
You'll very likely have something caught in your drain pump. First set the washer to drain and spin. If you hear a hum or grinding noise and the water in the tub isn't draining or it's draining slowly you have something in the pump. If you take the rear panel off you'll reveal the drain pump at the right front corner or maybe middle on this model. if you empty all the water from your machine you can take off the spring clamp (this can be tricky) attaching the thick rubber hose from your tub to your drain pump. (you may want to have some old towels ready) With this off you can feel around for what's blocking the drain pump's impeller. You may want to take the screws out that secure the drain pump to the base and the other spring clamp that attaches the drain hose to the drain pump. Good luck!
Oct 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Estate washer stopped after filling with water
will any of the lights come on when you try to turn on a cycle?
Nov 21, 2007 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
474 people viewed this question
Top Washing Machines Experts
