Question about Motorola Mobility MPx220 PDAs
Issues ! I have a mpx220 since dec 31 07 it decided to stop working, I cant access settings, i cant change the the sound of the phone to normal or silent or any other it is stuck in one, the date and the hour change because it wanted!!!. At the beginning it said that it had low memory then i erased all the messages as the income and out calls but still the same Please help me Natalie
  • Anonymous Apr 23, 2009
    my motarola mpx220 is a nice smart phone but resently the settings have seemed to stop working.I can not acsees the settings on the phone. ???
How to change ring tone on Mototrola MP#, 2.0MP cell phone
Send your phone an MMS file that includes the ringtone. Download the file and then set as ringtone.
Mark
Motorola Support
Apr 26, 2014 | Motorola Mobility MPx220
Mymotorola mpx220 says no service everytime and it had like a 2 hamlf moon sign next to service antena and i tried 10000 times to master reset after pressing yes it says processing and after 2 sec it shuts...
MPx220 - Master Reset How do I do a Master Reset? To do a Master Reset:
  1. Power the phone off.
  2. Press and hold the BLUE action key.
  3. While holding down the action key turn the power back on.
  4. You will then get a prompt asking for confirmation of a Master Reset.
Note: This will NOT delete the file manager but all memory contents and phone settings will be erased. Please recomend that any data be backed up before performing a Master Reset on the MPx220.
May 12, 2011 | Motorola Mobility MPx220 Pocket PC
How to piut spanish in mpx220 motorola
Please follow these steps: Go to Settings > More > Regional settings and select Spanish.
Mar 03, 2011 | Motorola Mobility MPx220
My motorola MPx220 is saying sim card failure plz help
try insert another sim. If it is not working take it to the service centre. Was the phone in water??
Apr 14, 2010 | Motorola Mobility MPx220
My MPx220 seems to be **** in flight mode no keys will work
When the back cover of the battery is removed it automatically goes into flight mode. Most likely the little plastic tab that pokes into the slot where the switch is could be broken? You can manually poke it down with a pin or paper clip and replace the back.
May 11, 2009 | Motorola Mobility MPx220
Battery not charging
I couldnt find an economical solution to that problem. The way I solved it is by buying a desktop charger. Chek out http://cgi.ebay.com/Motorola-MPX220-MPX-220-Battery-Desktop-Charger_W0QQitemZ300187068458QQihZ020QQcategoryZ83521QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
They have worldwide shipping.
Dec 21, 2007 | Motorola Mobility MPx220
No Vibrate
Unfortunately, the vibration mechanism is not in the battery. You will eiither have to get it serviced or get a replacement phone. I am very farmiliar with the MPX220 as I used to use one. When mine died, I replaced it with a Motorola Q. If you have GSM service, the GSM Q's are being relesed shortly.
Aug 09, 2007 | Motorola Mobility MPx220
MPX220: Sync failed + The settings could not be opened
This is the case that your phone previous setup has changed back to default setting since the phone is sold to you. I have my MPX220 before and sync with Windows Xp Service Pack 2 and Activesync 4.2 and everytime I came back, they automatically recognize each other both PC and my phone. I think in your case, you need to start over again by uninstall the activesync and reinstall it and then reconnect your phone back to start from step one. I think that is only way to refresh the connection of your MPX220 and your PC. I don't know why you has these problems but usually when you are done your setup at the first time, your PC recognize your phone with the current setup you have made but when your phone is completetly dead, it wipes out all related info which is necessary for both parts to handshake and only uninstall the sync software and reinstall it from fresh can solve this problem. windows 2000 is not as stable as win xp about these tasks. If you can upgrade to wins xp, you will never worry about this again specially windows xp with service pack 2. I hope this help
Apr 10, 2007 | Motorola Mobility MPx220 Pocket PC
Cellphone problem with activesync
There are few solution you can try: 1) uninstall ActiveSync 3.7 and reinstall it and start over agin for the sync process. 2) Try to install the newer version of Activesync 4.2, it may help to cure some bugs with MPX220. 3) But first, you need to install the Motorola Mobile Cd comes with the phone and upgrade the software to th emost recent version and reinstall this software. Now tehn try to reconnect the phone again and start the new setup. If you try all these options, the phone is stil l not be connected normally, then your phone may has some bugs in synchronization. If your phone is llocked to Cingular, try to unlock it first before do synchronization since this phone has this issue reported form many users. you are not alone. Good Luck
Sep 19, 2005 | Motorola Mobility MPx220 Pocket PC
Motorola Mobility MPx220 PDAs Logo
116 people viewed this question
Top Motorola Mobility Computers & Internet Experts
David Payne
David Payne
 Paul Flint
Paul Flint
Level 1 Expert
Unlockingcom
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
