Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
Sync music I installed the music essentials kit and transfered music from pc to phone with no problem. The next time it would not work. The phone reads connection failure and the pc message is that it did not successfully install usb driver for the phone and I need to insert disk that came with phone. No disk came with the phone. i tried different phone 9same model) and a different usb cable with no success
Ya i had the same problem. but one thing i did was start the music sync on the krzr BEFORE attaching it to the USB and for some reason then (and ever since) it will recognize my phone. but i can't get my pics or videos from my phone to my computer still!
Posted on Jan 06, 2008
Iphone 5 music sync
This way should fix the issue about sync music from iPhone 5 to PC without iTunes:
- After your iPhone 5 connected to PC, launch the program you will see the right UI.
- Choose the list and music files you want to transfer , Click the "Export" button.
- After you clicking the "Export" button, the following window will pop up, you can choose transferring to computer or iTunes directly. You can set the output folder at Advanced->Options before transferring.
- When the transferring finished, the following window will pop up.
Done!
Sep 30, 2012 | Apple iPhone 5
How do i download songs from my pc itunes to my iphone 4
There are 2 ways,
1) sync music to your iphone through itunes by selecting the music tab on itunes and select the song you want to sync
2) sync by manually dragging your music to the iphone icon in itunes. you will need to click off the box "manually sync files to iphone" at the bottom of itunes
Nov 21, 2010 | Apple iPhone 3G
I have a music kit for my Motorazr VE20 (alltel) yes Alltel should be Verizon but one still does exist. Anyways the music is on my computer but my phone just doesn't seem to "sync" up with it. Which in...
ok the music kit had virtually no instruction and was tricky main thing is you cannot hook up the phone and cable to the computer first or together first thing run the disc or download the software from the link listed in the booklet then plug in your cable no phone and reboot to detect the plug and play device it will run its own drivers just hit yes to everything and let the wizard install it then plug in your phone and it will run its own separate drivers again hit yes let it run and then it will be able to sync when you press sync it will pull all of your music to a file remember this location write it down or you will be lost if you unhook it whille its transferring or want to use it later then drag and click the music from your media player over to the music kit software it will transfer it over for you its alot i know im sorry let meknow if you have trouble i was an alltel customer serivce rep for three years ill do my best by memory to help you out since I was recently laid off from verizon downsizing the alltel call centers
May 21, 2010 | Motorola Mobility MOTORAZR VE20 Cell Phone
How do i transfer my music from my itune library to my iphone
Connect your iPhone to iTunes and do the following:
1.On the summary tab of your iTunes sync settings check "Sync only checked songs and videos"
2.In your music library check all the songs you want to sync to your iPhone
3.Make sure there are no exclamation points next to any of the songs you want to sync to your iPhone
4.Make sure you have authorized your computer for all Apple IDs for purchased music you want to sync to your iPhone (in Store>Authorize This Computer)
5.Check "Sync Music" on the Music tab of your iTunes sync settings
6.Sync your iPhone
If above can't help you, the below article may give you a guide.
Transfer music from my iTunes library to iPhone
Good Luck!
Apr 15, 2010 | Apple iPhone Smartphone
How do i transfer music from my pc to my android
Install the software that came with your Android or if Windows XP and above can see your Android use Windows Media Player (see notes below for Windows 7)
Sync music, pictures, contacts, and calendars with a mobile device
There are two ways to sync a mobile phone, portable music player, or other mobile device with your computer. You can install the sync software that many manufacturers include with their devices, or you can use the new Device Stage feature in this version of Windows if your device supports this feature.
Device Stage lets you sync music, contacts, calendars, and other files and information with a compatible mobile device. It also allows you to perform other device-related tasks that vary depending on the device, such as creating ringtones for a mobile phone. What files and information you can sync depends on the type of device you have and what it supports. For example, you may be able to sync contacts and calendars with a smartphone, but not with a portable music player.
To see which types of files and information you can sync with your device, connect the device to your computer. If your device is compatible with Device Stage, this feature will open automatically. (If you've already set up your device to sync, Device Stage will open, but it will appear minimized on your Windows taskbar.) Device Stage will list various tasks you can perform with your device, including sync setup.
The Device Stage sync setup page
Notes
  • Device Stage is customized for each device by the manufacturer of that device, and displays different options for different devices. If you have more than one device connected to your computer, you can have more than one instance of Device Stage open at the same time.
  • To find out if a device will work with Device Stage, you can also check with the manufacturer or look at the device specifications. For a mobile phone, music player, digital camera, or other mobile device to work with Device Stage, the manufacturer must add compatible software (also called firmware) to the device.
Jan 19, 2010 | Google Android
I cant transfer music or anything from my pc to my phone
Install the provided LG Dare software on your computer.
Using your USB cord, connect the phone to the computer.
Open windows Media Player.
Media Player should see your phone.
In the sync screen, drag music from your library to the sync column and then select sync.
This will copy the selected music to your phone.
Photos are easiest with a micro SD card, otherwise, you need software like BitPim.
Transfer photos to and from the micro SD card and the insert in your phone.
Aug 04, 2009 | LG Dare VX9700 Cell Phone
How to move or download a music file to be a ringtone
This option allows you to transfer music files from your PC. In order to use this option, you must install V CAST Music with Rhapsody on your PC. 1. Open V CAST Music with Rhapsody software. Don’t have V CAST MUSIC with Rhapsody software? Download it for free at www.verizonwireless.com/music. 2. Install the device USB drivers before connecting your phone to a PC. USB Cable and Device Drivers can be purchased separately via the Music Essentials Kit compatible with this device. 3. From the main screen on your phone, the SYNC MUSIC V CAST MOBILE PHONE display appears. Your phone should display the message: Connected. Connection may take a few seconds. 4. Drag and drop the song(s) you want to sync from My Library, to your V CAST Music with Rhapsody mobile phone, listed under the Sources tab. Once synchronization is complete, press the END/Power Key and disconnect the USB cable (purchased separately). 5. Under the Music & Tones menu, open My Music to view and play your music. • A compatible USB cable (sold separately) is required for syncing. • Music can also be purchased via V CAST Music with Rhapsody through your PC.
Hope this helps, let me know if I can help you with anything else.
JimmyC
Jun 17, 2009 | UTStarcom Blitz Cell Phone
MTP Device Searching Preconfigured Driver Folders
I was having this problem as well, but solved it.
I, like others decided to just buy a USB cable for my VX9900 and use Windows Media Player for sync'ing. (I also have the Verizon Essentials program that I downloaded, but I like WMP better. No particular reason).
I was getting the installation messages and as soon as the MTP message came up, I got the "problem" message and it didn't sync.
What I did when I got the cable was to run the CD drivers that came with my cable. That may have been my mistake. I was bothered that the date of my driver was in 2005 since the phone came out late in 2006. So I looked at the name of the driver and it was something like C:\Windows\System32\Drivers\LGUSBDriver.xxx whatever... I went to my device manager and uninstalled the driver. I went to the C:\Program Files\ and deleted the LG USBDrivers folder. I went to the Windows/system32/drivers folder and there were three LG*.* files I deleted them. The next time I plugged the phone in and set it to sync, it worked. It's late and night and I may not have typed this really clearly, so feel free to contact me at bill (at) halfamind.com (because a half a mind is still a terrible thing to waste).
Bill Isles
Apr 10, 2008 | LG enV VX9900 Cellular Phone
I NEED HELP PLEASE
you have to buy the music kit and then transfer the songs onto your phone with that and then you can move them onto your memory card
Aug 09, 2007 | LG CHOCOLATE VX8500 Cellular Phone
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
57 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
