Home | Maytag | Neptune FAV6800AW Top Load Washer | Not draining completely
Maytag Neptune FAV6800AW Top Load Washer
Problem for Maytag Neptune FAV6800AW Top Load Washer
By surfsmitty68 on Nov 04, 2009
Have a maytag neptune TL fav6800aw - Will not drain completely
Solution #1
posted on Nov 04, 2009
Not Rated)
FAV6800AWDIY
Rank: Wiz  Maytag Expert
Rating: 97%, 15 votes
Clutch Fix
Hello surfsmitty68 ,
A couple of questions;
Is the machine failing to spin with error codes such as dc or UC? If not are there any error codes to the LED console display on spin cycle failure? If there is a blockage in the drain pump/drain line you would fail with a ND error code.
Do you want to DIY the repair once we get going or do you want to call in a repair service? See this post Clutch Fix to see what is involved to re-lube/replace the clutch in the FAV6800AW or FAV9800AW TL. If you or someone has basic mech. skill sets you can do this it’s just a tight work area. But let’s get some feedback from you before we commit to a clutch issue.
Here are some handy links; The Service Manual for reference. Sears Parts Direct for reference.
Post back if you have questions or concerns I’m a owner like you. Let me know what I can do to help…. Rich… aka dh1200s.
Comments:
Nov 04, 2009
- Hey surfsmitty68 ,
To pump out the excess tub water while failing to complete spin cycle.
I would go to page 16 of the SM lower right hand part of page, Board Output Test and turn on the drain pump in service mode to pump out the tub.
Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
Pressing the Delicates key will lock the lid. Now press the Presoak key the drain pump will turn on. Stop with off button or hit the Presoak key.
I would also like you to test the Tub Displacement Sensor for proper operation;
You do this test thru the washer lid;
Tub Displacement Sensor Diagnostics check.
It is possible the Tub Displacement Sensor may have failed try this check which is in the Troubleshooting guide stored in your washer console or refer to the SM.
a. Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
b. Press the Super Wash key display reads “in”…something like that.
c. Press Delicates the Display will show “UC” (Unbalance Closed).
d. Push tub to the back right corner of the machine the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
e. Press Hand Wash.
f. Pull tub to the front left corner while pushing the tub down the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
What are your results?
If you fail this test it would be time to remove the machine front cover check if the TDS sensor has fallen of its mounting position between the Tub and the washer frame.
Was this helpful?
Yes
No
Popular Solutions for Maytag Neptune FAV6800AW Top
Questions and Unsolved Problems for Maytag Neptune FAV6800AW Top
Do you recommend Maytag Neptune FAV6800AW Top Load Washer?
Answer
Answer
my top loader will not hold water it keeps draning out!!
Answer
my maytag washing machine stop working totally mid cycle. I'm not getting anything when I turn and... (More)
Answer
My Neptune TL is not completely draining. I've got the tub out but am having trouble getting the big... (More)
Answer
I have the Maytag Neptune MAH8700 series. I keep receiving the E3 error. It seems to happen just... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Maytag Neptune FAV6800AW Top...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14739
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
