Question about IBM ThinkPad T40 2373 Notebook
Everything stops hi have a t41 l top switch it on and windows starts as normal and then everything stops working and seems if screen wants to move to 1 side.have restarted it in the safe mode and all modes but still no joy
    Sergeant:
  • 263 Answers
Loocks like you have or virus on your computer or your windows is corrupted so you may have to fix your windows system
Posted on Jan 05, 2008
Hi, H650, working fine, then erratically just stop, seems electrical problem, side stand switch were suspicious, took it off and bridged the wires, the same problem, Thx
Hi, Tamas the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
a. It prevents starting when the transmission is in gear and the side stand is up, but the clutch lever is not pulled.
b. It prevents starting when the transmission is in gear and the clutch lever is pulled, but the side stand is still down.
c. It cuts the running engine when the transmission is in gear and the side stand is moved down.
Periodically check the operation of the ignition circuit cut-off system according to the following tests.
With the engine turned off:
1. Move the side stand down.
2. Make sure that the engine stop switch is set to "RUN"
3. Turn the key to "ON".
4. Shift the transmission into the neutral position.
5. Push the start switch if the engine does not start the neutral switch may be faulty.
With the engine still running:
6. Move the side stand up.
7. Keep the clutch lever pulled.
8. Shift the transmission into gear.
9. Move the side stand down if the engine does not stall you may have a faulty side stand switch.
After the engine has stalled:
10. Move the side stand up.
11. Keep the clutch lever pulled.
12. Push the start switch if the engine does not start you may have a faulty clutch switch.
This check is most reliable if performed with a warmed-up engine.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Runs stops starts backfires
Engine turns off all of sudden when riding
Kawasaki Ninja 650 Service Manual
OEM Parts for Kawasaki
Kawasaki Ninja Owners Manuals
Apr 01, 2017 | 2008 kawasaki Ninja 650R
2005 equinox left front window some times will go up and down , however most times times it seems to stick won't go up or down unless you help it to start moving. Should you stop it half way it seems to...
I have a similar problem with the same window. The window doesn't stop moving but it tilts forward until it won't close properly leaving a 1 inch gap between the top left corner of the window and the door frame from the perspective of sitting in the drivers seat. I had the motor and regulator replaced but to no avail.
I took off the door panel, everything looked fine. Took off all the weather strips and the driver side mirror. Behind the mirror there is the top portion of the metal guide the edge of the window rides up and down. it was partially cracked and bulged out beneath the crack. I gently pounded it back in and cleaned out the guides on both sides with window cleaner and WD-40. The issue will not be completely fixed until I replace the metal guide but it runs much smoother now.
Apr 30, 2011 | 2005 Chevrolet Equinox
I have an IBM T41 type 2378 Windows XP Professional. I have been using and external monitor as the screen does not work. A while back I wanted to reformat my C drive and installed a windows XP disk I...
I would try to start it up in safe mode. This can tell you whether it's a display (physical) issue, or a driver (software) issue. You can do this by hitting the F8 button as soon as you start the computer and it brings up a prompt. At the Advanced system prompt, choose "Safe Mode with Networking" and see if it works then. If it does, I would suggest you undo an changes in the drivers that you made before.
Apr 01, 2011 | IBM ThinkPad T41 Notebook
Lcd screen stuck in external screen mode
How to use the function (Fn) keys on the keyboard - ThinkPad T40, T40p, T41, T41p, T42, T42p, T43, T43p
Switching the display output location.
Switch between the computer display and an external monitor. If an external monitor is attached, the computer output is displayed in the following three patterns by turns:
  • External monitor (CRT display)
  • Computer display and external monitor (LCD + CRT display)
  • Computer display (LCD)
Notes:
  • For any operating system other than Windows 2000 or Windows XP, no additional procedure is needed. Just press Fn+F7.
  • This function is not supported if different desktop images are displayed on the computer display and the external monitor (the Extend desktop function).
  • This function does not work while a DVD movie or a video clip is playing.
To enable this function in Windows 2000 and Windows XP, the following procedure is needed:
  1. When you log on to Windows 2000 and Windows XP for the first time, press Fn + F7 and select a display-switching function in the Initial setup window. Since in Windows 2000 and Windows XP multiple users can log on to a single operating system by using different user IDs, each user needs to select the function in the initial setup window when logging on for the first time.
  2. If the Fn + F7 key combination have been assigned to a presentation scheme function, start Presentation Director, and change the settings.
Feb 28, 2010 | IBM ThinkPad T41 Notebook
Toyota Celica 1988 - Drivers window not working.
Check under the Hood and see if you can Locate the Fuse Relay Box. There is a Relay in this Box for the Windows. Replace this Relay. You really need to try and Locate the Same Model Switch for the Drivers Door as that is the Problem there. Try and Find a Dealership in the States and see if they will Ship you one. Should not be a Problem. Just do a General Search for Dealerships in the USA and Pick. Let me know if the Relay does not work so we can go another Route for Repair. Please Rate my Solution, I need all the Help that I can Get! Thanks!
Jan 29, 2009 | 1988 Toyota Celica Liftback
Ibm t41 sound not working
Just to try the obvious...
The volume buttons on the laptop underneath the screen work independently to the volume controls in Windows. Have you tried pressing and holding the volume up button and then playing a sound?
Jan 21, 2009 | IBM ThinkPad T41 2373 Notebook
I have problem with mt laptop that is thinkpad t41
boot your system in safe mode remove its display driver, then boot in normal mode install the driver, then check
Nov 02, 2008 | IBM ThinkPad T41 Notebook
Ibm t41 thinkpad display problem
actually its the problem of the cable that gives display to your screen , open your laptop and replace this cable
rate this solution
Oct 15, 2008 | IBM ThinkPad T41 2373 Notebook
Everythg stops
hi, there can be two reaseons, 1) your RAM is bad or try cleaning the contacts with an ereaser, secondly, ur CPU cooling system might not be working, thats the reason the system shuts down.. try to solve both thgis issues one by one, i think u will be fine..let me know
Jan 04, 2008 | IBM ThinkPad T40 2373 Notebook
Toshiba eqium
hardware issue, i strongly suggest you take it back to the shop, replace with warranty if still available or get a pro to look at it. has this happened recently just randomly or since you have had it?
Dec 06, 2007 | IBM ThinkPad T41 Notebook
IBM ThinkPad T40 2373 Notebook Logo
55 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
