Samsung rear projection tv sp42w4hb
I just got a second hand 42in samsung rear projection tv and the blue blub is flashing slightley, it dont do it all the time, i looked inside and the red and green blubs are ok but some times the blue one flickers.
  • 8,617 Answers
I would check the CRT socket module for Cracked solder joints. If not you may be in the early stages of the CRT shorting, If so you will need a new CRT.
Posted on Jan 04, 2008
6ya staff
SOURCE:
Green and blue half circles on screen
hello it sounds like convergance chips might be your trouble it's a big job to do it yourself. best bet to get a quote good luck
regards
shaun
Apr 05, 2009 | Samsung HLN437W 43" Rear Projection HDTV
I have just been given a Samsung sp42w4hb back projector TV that has a problem,after about 4 power cuts in the area the TV went off and only the standby light comes on,it stays on for about 10/15 seconds...
check to see if you have a loose conection at the relay or at the power source a lot of times the relay goes bad and you can solder a neew one in get a service manual to locate relay and parts
Jan 21, 2009 | Samsung Televison & Video
Sony 42in- No picture or sound
You need to replace the bulb...very easy. You can do it yourself.
Dec 23, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Samsung tv SP42W4HB fails t power on!Please help!
Typically a convergence amp fails and causes the shutdown. There are two to handle the job so when one goes both should be replaced. This failure may also damage associated fuses and resistors.
Nov 06, 2008 | Televison & Video
Samsung pcn5425r faded blue?
You either need a new Blue CRT or the Blue CRT circuit board. You can get both those parts at the following link for a real cheap price as they have them used which cost a fraction of what they would be new. Leave them a email with your model number and what youre needing they will respond back quickly.
http://servicemanuals.vstore.ca/
Jun 10, 2008 | Samsung PCN5425R 54" Rear Projection...
No green or blue color in pictures!
You need to find a qualified servicer. You have component failure.
Look for TV Repair on craigslist or yellowbook.
Craig www.classtorations.com
Apr 20, 2008 | Samsung PCL545R 54" Rear Projection...
Samsung sp42w4hb Rear projection
needs new convergence ships, part number stk 392-040, there is 2 of them, replace them both, also check fuses on the board, you probably need a tv repairman to fix this.
Apr 09, 2008 | Hitachi 46F510 46" Projection HDTV
Blue and Yellow doubles
Well, fortunately the television that you purchased has an auto-convergence feature. What is happenning is that your color lamps are misaligned, did it get moved at all recently? Anyway, in your menu you should see a "Convergence" menu, and inside that menu, a section called "Perfect Focus". Run Perfect Focus in this sequence: Green --> Red --> Blue After that your picture should look great, if not try tinkering with the manual adjustments on the "Convergence" menu. Here are some URLs that you might find helpful: (just copy+paste into your browser) Your Television On Samsung's Webstire: http://www.samsung.com/Products/TV/ArchivedTelevisions_2002/HCM4216WXXAA.asp Your Television's User Manual (Download And Open With Adobe PDF Reader) (The "Convergence" Menu Is Section 3.3) http://www.usersmanualguide.com/samsung/tv__projection/hcm4216w
Apr 29, 2007 | Samsung HCM4216W 42" Rear Projection...
Samsung 42in rear prejection tv
If your remote is not a universal then you will have to take down the remote and clean it probly it is clogged with dirt.if that does not work then you will have to replace the remote.good luck.
Apr 12, 2007 | Samsung HCM4216W 42" Rear Projection...
Televison & Video Logo
108 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
