Question about Canon BJC 85 InkJet Printer
Drivers I am using windows 98 but aI must up grade will my bjc-85 work on windows 2000 or higher? Thank you wlharris43@att.net
  • 4 Answers
I use my BJC-85 with my Palm (ird), my laptop running win2000 and my desktop running winXP with no problems. Go to Canon and get the update for your OS.
Posted on Feb 26, 2008
  • 22 Answers
Hi Wlharris,
Bjc-85 will not support OS windows 2000 or higher, click on the below link to see complete product information by canon.
http://downloadlibrary.usa.canon.com/cpr/pdf/Brochures/BJC-85_spec.pdf
Note-This link works only if you have adobe reader installed on your pc, If you dont have adobe reader kindly click http://Click here.
Hope this post was useful to you, kindly let me know by providing your valuable rating.
Thanks,
Robosoft.
Posted on Jan 05, 2008
Installing a driver for a BJC-85 on a Dell Laptop running Windows 7 32 bit
There is no Windows 7 driver planned as this printer is obsolete on the cannon website.
It does not even support windows XP or Vista, only up to Windows 2000.
Mar 07, 2010 | Dell Inspiron 1501 Notebook
Cant find driver for Canon BJC-5100 to run on XPpro
I am sorry, but BJC-5100 cannot run on XP, as no driver has ever been released.
Here is the driver download page, for Win 98/Me and windows 2000.
Dec 08, 2008 | Canon BJC 5100 InkJet Printer
Canon BJC 3000 InkJet Printer Driver
According to this link (select Frequently Asked Questions, then the first item listed), the seller is correct for Windows Vista. For Windows 2000 or Windows XP, you can get the drivers at this link.
Oct 10, 2008 | Canon BJC 3000 InkJet Printer
I cant install my canon BJC-4100 printer
What OS are you trying to install it on, and how are you getting the files? The printer came out when Windows 95 was brand new, so using the original installation discs (floppies?) on any newer OS is not going to work. Canon has drivers available online for Windows NT, 95, 98 and Me here.
If you have a newer Windows 2000 or Windows XP use the drivers that are built in to the OS. From the Add Printer option, select Canon as the manufacturer, then look for Canon Bubble Jet BJC-4100.
If you have Windows Vista, this printer is not supported in that OS. Nor is this printer supported in any Mac OS.
Jul 28, 2008 | Canon Office Equipment & Supplies
What does disabling bidirectional support mean
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} USB to Parallel conversion requires translation by XP and Vista's 'hardware interleave' software as well as the USB device manufacturers driver. The software package just doesn't work well with older peripherals that use legacy parallel or serial com ports. Too many sloppy layers.
THE BEST WAY to add an LPT printer port to your laptop is to use a PCMCIA to Parallel adapter card.
The PC Card slot provides access to the laptop's data bus, and the PC Card adapter easily sets up as a native LPT port within almost any OS.
There is no delay, or connection problems as I've seen in so many complaints about USB to Parallel or Legacy Serial adapters. Printing is Instant.
PCMCIA is a mature standard, and works seamlessly with XP and Vista, and almost any other OS.
PARALLEL is the old standard fast data protocol. IEEE 1284 ECP mode up to 1.5 Mbps.
The BJC-80 and the BJC-85 have the same print speed. The BJC-85 just added USB.
INFRARED is ver 1.0 on the BJC-80, and printing is a bit slower at 115.2 kbps. Even the BJC-85 with its higher IRDA transfer rating and a laptop's built-in IR port, the XP print spooler has problems with it, and can hang if printing more than one page, and especially with more than one document. It will not scan.
I use IR for printing single pages only with either the BJC-80 or BJC-85.
USB to IRDA adapters work fine, and are less expensive $5-6 than
PCMCIA to Parallel adapters, $20-25.
I have tested and used several PCMCIA adapters from different manufacturers, and they all work perfectly as a hot-pluggable, instant LPT and/or Legacy Serial port for my laptops.
TIPS:
After installing the PC Card driver, check Device Manager for the LPT port number.
Install the printer manually from the list of printers, and select the proper LPT port.
Most laptops have two PCMCIA slots. If you change slots, the adapter card driver may reinstall, and assign the next available LPT port, LPT2.
To scan with the BJC-80, you must have an LPT port.
The PC Card adapter also allows the use of the IS-12 scanner cartridge within XP or Vista.
Within Vista, set the Canon ISScan software to run in Windows 98 compatibility mode, to allow use of the TWAIN driver.
Jun 12, 2008 | Canon BJC 80 InkJet Printer
Canon BJC 2000 question-1284 to usb
TIPS:
Jun 05, 2008 | Canon BJC 80 InkJet Printer
BJC 80 Won't Print
Try disable bidirectional support
Jun 02, 2008 | Canon BJC 80 InkJet Printer
Time consuming
Try installing the latest driver: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=230&modelid=7998
Aug 23, 2007 | Canon BJC 80 InkJet Printer
Canon BJC 85 InkJet Printer Logo
105 people viewed this question
old marine
old marine
