Reset the temp controls to factory settings c and 3 and clean the coils on the bottom of the frige. A few screws and the cardboard or metal panel on the lower back of frige will come off giving you access to condenser coils and fan. Unplug frige first Use a Vacuum and brush and be careful.
Your defrost system is out and this is an easy repair. Just contact us with your brand and model number and we will get the correct part out to you right away.
We also provide part removal/installtion instructions for folks that want to save money by performing the repair on their own.
We hope this answers your question and we look forward to working with you.
the water filter in the top right corner of the fridge started dripping water and freezing on the...
(More)
the water filter in the top right corner of the fridge started dripping water and freezing on the top shelf. i tried to tighten it and took it out and tried to re-install and it still drips and the water isn't coming out dispenser
ge pfss6pkwbss Icemaker fan motor not running at same time as freezer compartment fan located beside...
(More)
ge pfss6pkwbss Icemaker fan motor not running at same time as freezer compartment fan located beside it. Freezer reaches -14 degrees, refer runs 40-45 degrees. Icemaker will cycle on manual button and water volume is good. service filter display wont reset on door panel. After watching both motors for ten minutes the icemaker blower motor cycled for 5 seconds. The air duct was blocked with frozen condensate when I first removed the back panel; the evaporator was clear of ice with a good frost pattern.
