Question about Windchaser (WHF5000) Utility Heater
WHF5000 stops and does not starts again
Hi
my problem is that  a hetaer WHF5000 is adjusted to middle scale low power, it starts working OK, but suddenly stops and does not start anymore until you unplug de AC power wait for a 5 minutes and again same behaviour. Do you have any idea what couls cause the problem?
    Problem Solver:
  • 18 Answers
Buy a newer heater and save your money for good things
Posted on Jan 04, 2008
I have a proton arena bakie 1.5 my heater dose not work i have checked the fuse all is ok is there a relay and were.
Hi. Thanks for your question. For better assistance of hetaer of proton arena bakie 1.5 you can visit https://www.reliable-store.com and download the entire workshop manual which includes all the information along with the diagrams for better understanding. Good day!
Feb 28, 2017 | Proton Cars & Trucks
What is the calibrating code of toshiba e studio 2303a
(1)While pressing [0] and [5] simultaneously, turn the power ON. ? Adjustment Mode
(2) [SETTINGS] ? [USER FUNCTIONS] ? Select [DRAWER] ? Select [DRAWER1] ? Set the paper size to A4/LT. ? [OK] ? Set A4/LT for the paper in upper drawer.
(3) [CANCEL] ? [CANCEL] ? [SETTINGS] (Return to code entry screen.)
? [10]? [SETTINGS]? [START] (A gamma adjustment patch chart is printed out.)
(4)Place the patch chart for adjustment printed in step (3) face down on the original glass. Place the chart aligning its black side of the gradation pattern against the original scale.
(5)Key in a code "7165" and press the [START] button.
(6)If process finishes successfully, select "Yes" and press the [OK] button to apply the adjustments. (To cancel the reflection of adjustment results, press the [CANCEL] button.) In the case of an abnormal ending, "Error" is shown.
Press the [CANCEL] button to clear the error display. Next, confirm that the patch chart is oriented correctly on the platen and not at an angle, then do the process from step (4) again.
(7)Press [20] ? Press [SETTINGS] ? Press [START].
Notes:
•Compare with chart output in step (3), there should be no differences in patterns and no faint colors.
(8)Place the patch chart for adjustment printed in step (7) face down on the original glass. Place the chart aligning its black side of the gradation pattern against the original scale.
(9)Key in a code "7167" and press the [START] button.
(10)If process finishes successfully, select "Yes" and press the [OK] button to apply the adjustments. (To cancel the reflection of adjustment results, press the [CANCEL] button.)
In the case of an abnormal ending, "Error" is shown. Press the [CANCEL] button to clear the error display. Next, confirm that the patch chart is oriented correctly on the platen and not at an angle, then do the process from step (9) again.
(11)Turn the power OFF.
Sep 04, 2016 | Toshiba Office Equipment & Supplies
WHEN I START UP MY TRUCK THE WHEELS SPIN IS THAT IT DOES.I WANT TO KNOW IF THIER ANYWAY I CAN MAKE THEM STOP.
turn down your idle screw and adjust your low speed screw to fix the problem that made you turn your idle up in the first place if you let the truck idle for 7 1000s and you mash on the gas it will do one of 3 things:
1) a nice crisp throttle response= perfect low speed setting do not adjust
2) engine bogs down = too rich, lean out low speed screw 1/8th turn until fixed
3) truck revs up but shuts off= too lean, richen low speed screw 1/8th turn until fixed
Nov 20, 2010 | Exceed-RC 1/8TH Scale Exceed RC Nitro Gas...
Dodge dakota 2005 automatic transmission, when starting from a stop or low speed sounds as if it is low on fluid rpms high started doing this on tollway when pulling out from the toll both ????seems to...
Manually shift thru all gears up & down the scale. Try adding Motorcraft Additive Friction Modifier, available from Ford parts dept. This REALLY STINKS!!! Don't get any on you. Pour into trans fluid. Drive a few miles shifting manually thruthe gears, then do a normal start stop drive several times. This will luburcate trans, normally used for differential but has worked in automatic transmissions of all makes for years. Otherwise mechanical problem for transmission repair facility.
Nov 07, 2010 | 2005 Dodge Dakota
My bathroom scales ww35cha stopped working, i replaced the battery and now the scales turn on, but do not display a weight when u step on. Instead the weight shows '0'
you have 4 button on this model
1 tap the scale to start, it show 0.0
2 tap set to set person and height, age ...( use set, up, down buttons )
done
when start use
1 tap scale to start , show 0.0 again
2 tap user again and again to choose your user
3 wait after it show your height, age, then it show 0.0 step on the scale and you're done.
i've been through becuase my friend lost his instruction manual.
Now it wook
Have Fun
duccotam@yahoo.com.au
Nov 16, 2009 | Conair Weight Watchers WW35 Body Fat Glass...
Carburetor adjustment on McCulloch Mini-Mac 30
turning Hi & Lo mixture screws in leans the mixture,out rich-ens it.turn the T screw in to increase idle speed the chain should slowly come to a stop at idle [chain brake off] adjust Low needle first until it accelerates smoothly then Hi needle for best 'revs'.then Lo again if necessary if you don't know where they were set before,start w/ screws 3/4 to 1 turn out from a lightly seated position
Sep 23, 2009 | Garden
No power at low revs but works a treat at higher revs.
maybe its your carburetor it might need adjusting.
Jan 14, 2009 | 2000 Yamaha DT 125 R
Washer stopped in the middle of the cycle
sounds like motor if nothing stuck between tubs or in pump ,check these first if ok you have bad timer
Nov 12, 2008 | Kenmore 22422 Top Load Washer
Stopped running in middle of cycle
hi thanks for the question when your dryer stopped and you tried to restart if no noise the over load thermostat embedded in motor is suppose to open and not allow it to start then the motor cools down now it works till the motor over heats again and shuts off again. i would vacuum out the inside clean motor and check the venting right to the outside and try it again but remember do this with power off thanks the appliance doc
Aug 31, 2008 | Whirlpool LER5636P Electric Dryer
Windchaser (WHF5000) Utility Heater Logo
54 people viewed this question
Top Windchaser Heating & Cooling Experts
Jay Finke
Jay Finke
Jake's Auto Care...
Steve
Are you a Windchaser Heating and Cooling Expert? Answer questions, earn points and help others
