Question about Whirlpool ER6AHKXPQ Top Freezer Refrigerator
Whirlpoor Refridgerator 10-12 yrs old
My fridge recently starting making this chachunk, chachunk noise when it stops running. Other than that noise, its working great.
Any ideas?
Thanks.
Claire
    Sergeant:
  • 288 Answers
I had a whirlpool fridge that did the exact same thing. Sometimes it was loud enough to wake me up at night! It is the compressor shutting down. I had it for several years untill I purchased a larger one, and then gave it to a girlfriend at least a year ago. Its still working good today. So if you can tollerate it, just live with it. Otherwise change the compressor.
Posted on Jan 09, 2008
GE Profile stopped making ice. 2 yrs old
clean the coil behind the fridge or under the fridge (where ever they are) and make sure both fans are running, the one in the freezer and the one underneath freezer needs to be 0 degree F to start ice maker
Aug 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge motor is loud when doors closed stops when open-3.5 yrs old- first time same problem fixed with replacing sensor 2/08 now sensor broken again???
the fan goes off when door opened and when closes it will turn back on is normal operation of fan and door control --as to noise --fan may be failing ---iced over ----if seal failing will cause unit to run more and allows more moisture into evap which can cause more ice over
Apr 25, 2017 | LG LRFD22850 Bottom Freezer Refrigerator...
Fridge makes a fairly loud humming noise when I close the door
it sounds like your refridgerator might be unlevel try adjusting the legs all the way down to start then level to floor if that doesnt fix it its probably the rubber gromet under the compressor usually there is four of them if one comes out(usually after moving it makes your compressor vibrate you can use almost any gromet of of any junk refrigerator or if you want you can by original replacement parts at one of your local appliance dealer
Dec 18, 2008 | Dishwashers
Hotpoint side by side has recently bugun making a lot of noise
Check for frost in the freezer compartment that may suggest a defrost problem which would cause it to run for extended times and make more noise. The other possibility is that if the fan is making a up and down type of noise, it will need a new fan in the freezer section due to a faulty bearing in the motor.
Oct 23, 2008 | Hotpoint (HSM25IFTSA) Side by Side...
Samsung side by side refridgerator making noise and freezing
its a heater cycle problem..the defroster is not working properly. its building up ice in the evaporator that touches the evaporator fan that makes that loud noise but stops when you open a door. it could be either a bad heater, a bad thermo disc or a bad timer.hope i was able to help
Feb 12, 2008 | Refrigerators
Inglis Refridgerator
No the fan must stay or your Fridge will not cool, I hear this same problem from a lot of people that have new Fridges. all new fridges are louder that the older ones, check to see what setting you have your control set at. Try turning it down to 3 or B this will make it run less. other than that, if it is cooling ok. then that is just the way it is. I hope this helps
Dec 22, 2007 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
Whirlpool Refridgerator + ET1FTTXKQ02 - Water leakage!
Own the same model, the icemaker and the dispenser work properly but the leak is top center of the refrigerator compartment.
Nov 08, 2007 | Whirlpool ET1FHTXM Top Freezer...
Fridge stopped working suddenly
Sounds like the relay (start device) on the compressor has failed.  This is a very common problem especially for models that are 3-5 yrs old.  I would replace that first.
Oct 22, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Whirlpool ER6AHKXPQ Top Freezer Refrigerator Logo
314 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
