Bios wont start in normal mode
  • 243 Answers
Have you tried the "last known good configuration" setting?
Posted on Jan 04, 2008
  • Graeme Fallows Jan 07, 2008
    Please rate my answer if it helped ? Cheers!
I updated BIOS to ACER V1.1612/18/2010 now it wont start windows normally I can only use in safe mode how can i reset or remove this Bios version or install previous version?
Not sure on how to reverse bios upgrade suggest if you have the original operating system to be contacting Microsoft and explain that you have changed the bios and windows needs to be altered to get another license key for the bios change to install it onto this bios. You may be in trouble if it is OEM version of windows but Microsoft will advise you on your options.
Feb 17, 2016 | Acer Computers & Internet
I'm having problems installing Ubuntu on Windows 8.
you have to change the settings in bios setup. normally press f2 or f10
Dec 21, 2017 | Dell Latitude D531 Laptop Computer PC...
I have a dell 9300 that loads bios fine but wont load os even after a complete reinstall? Diag runs threw just fine? it loads to safe mode or normal or bootlog. but then upon entering any option bios...
You might want to play with the BIOS options on the hard drive. If it shows AHCI change it to SCSI then vice versa if the are other options given.
If it still doesn't work, try moving the HDD to a diferent SATA port to check if the OS will load.
If not, it's a possible problem with the HDD.
Let me know what happens next.
Hope this helps!
Aug 07, 2011 | Computers & Internet
I changed my os from windows xp to windows 7...and i am using amd sempron (tm) processor 3400+ 1.80ghz..and 40 g hard disk..then the windows start up wont start normally. pls help!
Try hitting F8 just after your bios splash screen, before it would show the windows logo.
Select, boot in safe mode with networking.
Once you are in windows 7 safe mode, you can install any required drivers. This might prevent it from hanging on the next normal boot.
You can type in the run dialog CMD. This will open a command terminal. Type "SFC /scannow" without the quotes. This will tell windows to verify it's files. Let it complete, then reboot normally. Hopefully the problem will be resolved!
Mar 25, 2011 | Computers & Internet
Lenovo y510 wont start in normal mode (xp)
For the Lenovo to to start in the safe and networking mode, and then not have a display when you attempt to boot it in normal mode, I would follo the these steps:
Boot in networking mode, and then go to the Lenovo site and download the most current display drivers. Since you are able to operate as described above, I would start here first. Once you have successfully downloaded the most current drivers for the video on your system, BEFORE you leave the Lenovo site, check your system against the listed bios upgrades. I believe you may find you need to upgrade your system firmware. If the upgrades you need, and finish the display drivers updates as discussed above, and keep the fresh firmware updates set aside and see if the display driver updates allow you to boot normally.
If so, once you have a normal boot, backup your systems RIGHT away! The next step is to then carefully read the docs about how to update the firmware. Sometimes this will require a floppy drive, if so, you can most likely either pick up a USB one very cheaply or perhaps borrow one. At any rate, make sure your system is backed up fully, and preferable with a restore point, (if you are able with XP?)
Try these measures, if it is successful I would love to hear that from you by way of a testimonial. If you are not - please return here for further assistance. I have additional help for you - but I do not think at this time you have a hardware problem.
Have a great day!!
May 16, 2010 | Lenovo IdeaPad Y510 Notebook
Intel DesktopBoard D845EPI Problem automatik open Bios
change jumper to its normal position then plug out ur powercable,now u see there is 1 battery in motherboard just remove it and start pc for a sec and then shutdown again and put battery back,start ur pc and check
Mar 07, 2010 | Intel Desktop Board D845EPI Motherboard
Vaio wont start up shuts off
check two things, video (reinstall drivers) and the other may be a heat event, look in the BIOS set up in the event log.
blow dust out with compress gas especially around the heat port and exhaust fans.
May 15, 2009 | Sony VAIO VGN-FS840/W Notebook
Clear your bios, remove your all pci cards & then try.
Feb 23, 2008 | Intel D845GVSR Motherboard
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
