Question about Lasko 1155 Humidifier
Lasko 1155 fishy smell
Even after cleaning and filter change the humidifier emits a fishy smell tha engulfs the whole house
0 characters
1 Points
White dust in the house
Use mini RO system or good filter to feed humidifier with water that contains less minerals.
Jan 24, 2013 | Honeywell HE360A1027 Whole House...
What can you use to clean the filter or is it best to replace it with a new one?
Best thing is to always replace with a new one, the filters are not that expensive and very easy to change.
Jan 16, 2011 | Honeywell HE260A1010 Whole House...
How do I change the filter on Sunbeam Model SCM 2412 humidifier?
Turn the unit off and disconnect from the electrical
2. Remove the tank from the housing.
3. Unlock the housing from the base by turning the lock
knob to the unlocked position.
4. Lift the housing straight up and place to the side.
5. Unlock the wick holder from the base by turning the lock
6. Remove the wicks from the wick holder.
7. Follow the weekly cleaning instructions.
8. Insert new filters into the wick holder and lock the wick
holder back onto the base.
9. Replace the housing onto the base and lock it into place.
10. Fill the tank and place back into housing.
11. Repeat Operating Instructions.
It will take about 30 minutes for the humidifier to reach
Nov 03, 2010 | Sunbeam (0013871361) Humidifier
Moldy smell
Replace humidifier media pad (filter) with a new one, and clean interior of humidifier housing with a solution of warm water and vinegar, also replace or clean furnace filter, Good luck.
Mar 02, 2010 | Humidifiers
Water keeps running to Honewell 360A Whole House Humidifier
You may need to replace the valve that is wired to the furnace that controls the water flow
Feb 01, 2009 | Honeywell HE360A1027 Whole House...
Small rubbery piece has fallen off
I contacted Lasko and immediately got a response:
You will need to remove the top grill of the humidifier to install the gasket. The gasket installation instructions are as follows.
  1. Unplug the humidifier.
  1. Remove the top half of the humidifier and turn it upside down onto a stable surface.
***Be sure that the pump housing is dry. If it is not, there is a possibility that water will flow into the motor housing and cause damage to the motor.
  1. Locate and remove the six (6) screws that are around the inner edge of the unit.
3 are located near the front and 3 are located near the back.
  1. You will now be able to remove the top grill to install the gasket into the U shape part of the housing.
  1. Once the gasket is in place, you will then reassemble the top grill to the housing and reinstall the screws.
Apr 24, 2008 | Lasko 1115 Humidifier
Lack of humidity
Try the following test, ( I will resume this is a flow through humidifier)
Spray water directly oin the filter make sure it is saturated. Some water should leak from the bottom. After 10 min measure the Humidity to see if this helped. If there is a higher level of humidity the pbm is that not enough water is saturating the filter. Check the level of the filter & water feed nozzle.
Option 2 is to connect the water feed tube to a Hot water source.
Hope this helps.
Dec 28, 2007 | Honeywell HE220A1019 Whole House...
Humidifiers Logo
83 people viewed this question
Top Lasko Humidifiers Experts
Barrett Palumbo
Barrett Palumbo
Are you a Lasko Humidifier Expert? Answer questions, earn points and help others
