Question about Honeywell HE360A1027 Whole House Humidifier Humidifier
Honeywell HE360 humidifier won't work with Honeywell IAQ thermostat
Will this thermostat work withh the humidifier? We cannot make it function.
2 Suggested Answers
  • 1865 Answers
SOURCE: Honeywell TrueIAQ humidifier wiring
email the schematic to me at
Posted on Apr 15, 2009
  • 114 Answers
SOURCE: tank is broken on Honeywell HCM-560 humidifier.
you type in on the internet.
in the search bar type in your model number. it might take a minute to load but you will have 3 pictures that come up. click on any of them and scroll down alittle until you see water tanks. you can order them there.. or if youdon't want to go that route you can always try local hardware stores to see if they have it as well.
Posted on Aug 21, 2009
0 characters
1 Points
He360 fan and water run continuously
Check yor wiring, make sure you have sail or pressure switch wired in series with humidistat to humidifiers 24V power. Pressure or sail switch will disconnect humidifier when furnace fan is off. Humidifier (110V) could be connected to any closest electrical outlet.
Nov 10, 2013 | Honeywell HE360A1027 Whole House...
Fan and water run continuously on he360
I'm not sure what wiring option did you use, but looks like you did not include pressure or sail switches... When the furnace blower/fan is off it should open the 24volt circuit and close the water valve (normally close) and turn off the fan. If you can post more wiring details maybe pictures or hand sketch I'm sure problem can be fixed in the few minutes.
How do I remove the thermostat cover to change the battery?
Many of the newer Honeywell models have a battery compartment that can be accessed without removing the thermostat.
Look for a small tab at one of the top corners of the thermostat. If this is not the case try pulling directly away from the wall at the bottom, then tilt up.
Aug 27, 2010 | Honeywell Power Humidifier: Furnace...
I have a Honeywell Chronotherm III Thermostat and in instead of showing the temparature in the display it shows -AC. I've replaced the batteries, and tryied adjusting Temp up and down for cooling and...
It would appear to me that you have lost the 24 volt power supply to the thermostat. In referencing the manuals for this thermostat, available @, I've found that when the thermostat is not connected to the wall plate (plate mounted on the wall, that the thermostat either snaps or screws into), it will display the -AC. This being said, either the thermostat is loose on the wall currently, or your 24 volt transformer has died. Hope this helps.
Dec 23, 2009 | Honeywell Power Humidifier: Furnace...
Thermostat does not read current settings or respond to commands.
Go to
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
Oct 08, 2009 | Honeywell Power Humidifier: Furnace...
Water constantly running in honeywell humidifier
I has the same problem with my HE360 unit. The unit was in fact miswired. The head unit red wires were connected directly to the blue solenoid wires, and activated the solenoid without any signal from the humidistat. As soon as the unit is plugged inn, the water starts running without any signal to the unit. If your unit is miswired, the soleniod blue wires need to be cut and connected to the red crimp connectors.
Mar 11, 2009 | Honeywell HE220A1019 Whole House...
Honeywell HE360A1027 Whole House Humidifier Humidifier Logo
Top Honeywell Humidifiers Experts
Barrett Palumbo
Barrett Palumbo
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
