Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Problem for Whirlpool Ultimate Care II LSQ9549L Top Load Washer
The water dispenser from my whirlpool is
By val68 on Nov 04, 2009
the water dispenser from my whirlpool is constantly leaking a lot of water. Started every 1/2 hour leaking some water a time but now is a cosntant stream
Solution #1
posted on Nov 04, 2009
Not Rated)
jtbjtb
Rank: Guru
Rating: 89%, 61 votes
Replace the water inlet valve, located outside lower rear. Send model # to help@timerking.com for part # lookup. Hope this helps!
Was this helpful?
Yes
No
Solution #2
Not Rated)
localwonder
Rank: Guru  Whirlpool Refrigerators  Expert
Rating: 92%, 3268 votes
HI. This is being caused by a faulty inlet valve. This will be the culprit. Debris may be preventing the valve from closing. If the valve cannot be cleaned, it will have to be replaced. The valve can also fail mechanically. So even if it passes the electrical test, it may still require replacement.
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors
Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush, or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Was this helpful?
Yes
No
Solution #3
Not Rated)
e-Guru
Rank: Wiz  Washers & Dryers  Expert
Rating: 84%, 306 votes
You need to get access to the following instide . On the bottom of the faceplate there should be two small pry spots to remove faceplate. once the faceplate is removed you should have acess to the inside. Check for the leaks and seal them.
Thanks for contacting Fixya.com
Was this helpful?
Yes
No
Popular Solutions for Whirlpool Ultimate Care II
Questions and Unsolved Problems for Whirlpool Ultimate Care II
Do you recommend Whirlpool Ultimate Care II LSQ9549L Top Load Washer?
Answer
Answer
it wont spin. i looked underneath to see if there was a broken belt but seen what looked to be... (More)
Answer
my washing machine is making a horrible sound. I just started the load. It filled with water and... (More)
Answer
washer doesn't spin in any selection. agitates but no spinning when it drains. any suggestions???... (More)
Answer
all cycles work except for the wash cycle..the rod quit turning or slightly turns
Describe your Washing Machines problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
in Baltimore, MD
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
