HI If you are asking for pin contact your service provider , he will give you a default pin . If you try pin more than few predefined no of times your phone will ask PUK code which can also be given only by your service provider which is specific for each and every mobile number . Donot try PUK code many times or else your sim will be blocked and you will need a new sim. Contact your sim customer care department over phone. Its free of cost to get the pin or puk no. Go to the nearest service outlet of your service provider they can also help you. There is no other go than the above procedure only your service provider can give it nobody else in this world nor any software.
When some calls or I ring out the audio is low even though the volume is turned all the way up? I...
(More)
When some calls or I ring out the audio is low even though the volume is turned all the way up? I cant hear the other person very well
when i turn on my k850,my hp has no display,but the light keep turning on and i can't turn off...
(More)
when i turn on my k850,my hp has no display,but the light keep turning on and i can't turn off manually,i have to unplug the battery first.How do i can fix it?
My Sony Ericsson k850i is behaving strangely in regards to the SELECT softkey not working on the...
(More)
My Sony Ericsson k850i is behaving strangely in regards to the SELECT softkey not working on the touchscreen. However pressing the number pad acts as SELECT instead, so attempting to type a message or even dial a phonenumber is a complete nightmare. I tried doing a complete system reset but the problem persists.
