Home | Mitsubishi | WS-55809 55 in. Rear Projection Television | I have Mitsubishi mod...
Mitsubishi WS-55809 55 in. Rear Projection Television
Problem for Mitsubishi WS-55809 55 in. Rear Projection Television
I have Mitsubishi model WS-55809 55 in. projection
By brian_t_kanc on Nov 04, 2009
I have Mitsubishi model WS-55809 55 in. projection TV that the picture is bowed or concave at top and bottom. Sometimes when I hit the top of the TV, it gets better. Please help as this picture is very annoying.
Thank You.
Comments:
Nov 04, 2009
- donzaca - this makes no sense. Can you re-write this so I can understand it?
Solution #1
posted on Nov 04, 2009
Not Rated)
Abrsvcs
Rank: Guru  Televisions & Videos  Expert
Rating: 88%, 1809 votes
The problem is with the convergence circuit that is controlled by a couple fo convergence ICs. These are large black ICs attached to a heat sink and are marked STKxxx. Since a good whack seems to fix the problem, it suggests that the connections to the pins on these ICs has broken. This is a common failure adn is easily fixed. Please note that there are potentially dangerous high voltages present inside the set even when itis unplugged. If you can solder, resolder the pins on the ICs. That should resolve the problem. If not, then there is an internal bad connection within the ICs and they should be replaced. The parts cost is around $25-$25 per IC. There are 2 in this set.
Good luck,
Dan
Was this helpful?
Yes
No
Solution #2
Not Rated)
donzaca
Rank: Wiz  Televisions & Videos  Expert
Rating: 70%, 82 votes
has a problem on the cards are not making good contact is requested revicion cold welding technique
Comments:
Nov 04, 2009
- has a problem on the cards are not making good contact is requested revicion cold welding technique
Was this helpful?
Yes
No
Popular Solutions for Mitsubishi WS-55809 55 in.
Questions and Unsolved Problems for Mitsubishi WS-55809 55 in.
Do you recommend Mitsubishi WS-55809 55 in. Rear Projection Television?
Answer
Answer
Trying to figure out to find my television code for media center Mitsuibishi Medallion CRT
Answer
when purchasing replacement convergence IC STK392-570 are they specific to the TV brand, I see... (More)
Answer
I turned on my Mitsubishi ws 55 in TV and was going to play my PS3 when I received no picture. This... (More)
Answer
as soon as i turn on the tv it turns off it clicks on then 2 seconds later it clicks off. i self... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Mitsubishi WS-55809 55 in....:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
