Ricoh FAX5000L Plain Paper Laser
Error code 0-09
posted by an2ny on Jan 04, 2008
do anyone there knows how to reset the code 0-09 for ricoh aficio 5000L
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jan 06, 2008
Helpful (85)
jaylex
Rank:Guru Guru
Rating: 85%, 344 votes
Hi there I can only find in the service manual 6-09 and 9-09 I will attach the reasons for both if they are of any help great if not there are no tech bulletins for this machine that says otherwise.
Thanks J
9-09 Paper jam in the fusing exit
area
If the problem persists, replace the FCU.
6-09 G3 ECM - ERR received Check for a noisy line.
Adjust the Tx levels of the communicating
machines.
See code 6-05.
6-05 G3 ECM - facsimile data
frame not received within
18 s of CFR, but there was
no line fail
Check the line connection.
Check connections from the NCU to the FCU.
Check for a bad line or defective remote terminal.
Replace the FCU, FCU or NCU.
Try adjusting the rx cable equalizer
Cross reference
Rx cable equalizer - G3 Switch 07 (PSTN), G3
Switch 08 (PABX)
Comment posted on Jan 06, 2008
Sorry I found what you are looking for and it is as follows
0-09 Fusing unit failure (thermistor error)
Turn the machine off then on again and If the problem persists, replace the FCU. (Fusing Unit)
Thanks J
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on error code 0-09:
I don't want to Accept this solution
Can you Help with these Fax Machines problems?
Fax Machines
Hi I have a Lexmark 5600 and I am trying to send a fax...
Fax Machines
Registration of new Lexmark Z55 Color Jetprinter Cannot...
Fax Machines
I have a new Epson Workforce 500 All in One,I can send out...
when resetting the fuser unit failure switch, after...
need to reset service code 06 appeared when electricity...
Loading problems.
Repair Service
Find Fax Machine Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
