Question about Kodak Digital Science 2500D Path-Through Scanner
Kodak 2500D error
I'm receiving an error that i am not familiar with on my Kodak 2500D. The error says "U18 Remaind Doc 18400000" if you could give me some guidance with this issue I would be very grateful.
Andrew Briscoe
Doc2-Efile Inc.
  • Anonymous Apr 21, 2008
    Same U 18 Remaind doc. 1808000
I have had the same problem. That error represent a document still in the scan path. You will probably find there is no paper in the scanner. I tried this and it works every time. On the top of the scanner there is an access door. You will find this just above the discharge rollers. Open that door and either blow air in the compartment or blow hard using your mouth to clear dust. Close the door. That should resolve the problem. It is my guess that dust collects on sensors and the scanner is tricked into thinking there is paper in the path.
Posted on Feb 18, 2008
  • 25 Answers
Hikerman is on the right path! U18 codes can be generated by paper in the scanner, but also by anoying paper dust. There are several sensor holes you will see (lower and upper) when you open the scanner transport. There is also the paper exit sensor that Hikerman talks about.
My advice... get some canned air and blow the heck out of every hole you see in the transport path.
Posted on Jul 07, 2008
    Problem Solver:
  • 5 Answers
Thanks for leading me down this road. I blew the heck out of the scanner, no dice. I then noticed what was actually the page sensor and the one on the bottom (base portion of the scanner), had come unseated and was partially blocked by the metal. I unscrewed the metal plate that covers it and noticed that there were no screws attaching it, but some "bumps" and a flang, I reseated and worked like a charm.
Posted on Oct 22, 2009
I did the same thing, got canned air and blew the heck out of it, and I was amazed at the small bits of paper and dust that blew out. Thanks for this advice!
Posted on Jun 16, 2010
Hikerman, you are the man.......!
Thanks for the solution this actually worked very well, and my scanner is up and running fine.....
Thanks for the advice again. ;)
Posted on Apr 14, 2009
  • MyEfact Dec 22, 2010
    This problem is reported a lot because it seems to be unexplained: The scanner is reporting paper in the scanner, yet there is no paper in the scanner, nor is there any dust on a sensor.
    Turns out there is a normally hidden sensor that can get dust and cause this problem. Read more athttp://www.myefact.com/kb/the-u18-180400...
I have the Kodak EasyShare V530 and every time i turn it on it gives me a message that says "camera error #E45 see user's guide" then it turns off. Unfortunately i dont have my user's guide. Is...
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=21cc7420d5ae338b61a176f16d1146f3&modelid=200385&q=Kodak+V530
Here is the link to download your manual.
The error code indicates that there is a stuck lens issue.
Check to see if any foriegn matter...i.e. dirt, has gotten into where the zoom lens opens out at. That is more than likely the point that is causing this error.
Jan 18, 2011 | Cameras
We are gettign this error on our Kodak 2500D scanner U18 REMAIND DOC. 18040000
Hi what you need to do is download the latest firmware this should solve your problem
Mar 05, 2008 | Computers & Internet
Tip
Kodak 2500 scanner tires
Several years ago, Kodak stuck it to the owners of Kodak scanners. A simple, inexpensive consumable, tires, were taken off the market as a cheap thing to buy and they made it part of a care kit which just sent the price sky high.
If you own a 2500 Kodak scanner you can replace the retard tires with #13 O rings. They can be purchased from any Home Deport, Lowes....You will need a total of 12 O rings and that will cost you less than a buck. They work!!! I have been using them without incident for 2 years.
on Feb 18, 2008 | Kodak Digital Science 2500D Path-Through...
I have an Aspire 5050, I have bought a Kodak All in one printer. When I try to install it it gives me error code 1721. I was on the phone for 4 1/2 hours with Kodak and they advised that it is something...
Error 1721. There is a problem with this Windows Installer package. A program required for this install to complete could not be run. Contact your support or package vendor.
Sep 03, 2010 | Acer Aspire 5050-3242 Notebook
Evesham 7211 u18 IC fault
ws-20l is the markings on this IC
As to what it is....that's another story!
Mar 24, 2010 | Evesham Nav-Cam 7700 GPS Receiver
Error on display
you need to check on the connecting cables if damage replace,you can as well check my computer in system programms on monitor/visual display unit to see new device connected to system, after that restart your system.
Jul 09, 2009 | Office Equipment & Supplies
U18 remaining doc. error code;
The sensor that you can't see (at the bottom facing up) needed to be cleaned. Once cleaned with a cotton swab and alcohol the scanner works fine.
Apr 03, 2009 | Office Equipment & Supplies
Line on far right of scanned documents
Most likely the scanner has dirt on the glass that is over the imaging array or the glass may be scrached. If the glass is scratch, the imaging CCD array need to be replaced. If you do not scan the rear of your documents, you can swap the upper with the lower in the case that one is scratched.
The imaging array are the green long bars, one at the bottom of the paper path halfway inside the scanner and the other is above it. Look closely for a small spot of black toner or dirt stuck
on the glass. Take a soft cloth, wet it with water or alcohol if needed and clean the glass.
Pass you finger over the glass, try to feel if all of the toner or rubber residue has been removed.
You might try looking at the specific area were your documents image is getting the line. It will
help you pinpoint where you should clean. CAREFULL not to push on the glass as this
might break it. Hope this helps.
Otaron
Sep 08, 2008 | Kodak Digital Science 2500D Path-Through...
KOdak 2500 D -- cannot find target device
Go to Kodak's website and download the scan verification tool (the SVT), and see what it tells you. I use the 2500D with an Adaptec 2940 SCSI controller, and a 50-50 pin SCSI Cable.  I use the twain driver from Kodak's website and paperport 9 software.  This combination seems to work.
Jul 14, 2008 | Kodak Digital Science 2500D Path-Through...
Kodak Digital Science 2500D Path-Through Scanner Logo
1,027 people viewed this question
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
