Question about Uniden BC370CRS Base Scanner
Resetting dosen't work as per the manual - Uniden BC370CRS Base Scanner
  • micronta Jan 07, 2009
    Resetting the Uniden BC370CRS base scanner. Yes, taking out batteries & unpluging power supply does the trick. The manual fails to tell you this.
    Thank You
Turn the scanner off,remove the batteries,pull the power cord out of the scanner,push and hold the 2, 9 and hold buttons.While holding the buttons in, plug the power cord back into the scanner.This will reset the scanner to default settings.
Posted on Feb 22, 2008
The radio is off dosen,t turn on
Check your manual for the radio reset resolution. Some have a code, and some have a sequence on on/off ignition processes that may do the trick. If all else fails, call your favorite mechanic for a quote to reset your radio. Do your homework first, so you don't have to pay a fabulously high service bill, just to get your groove back. Good Luck! :)
Dec 14, 2014 | OEM 2003 Volvo V70 Radio / CD Player...
Samsung dvd player display says "protection" . Wont turn on.
Swtch off and disconnect and reconnect all the wiring especially speaker wires.
Also try resetting as per manual.
If that doesn't work then could be capacitor blown on motherboard.
Aug 06, 2014 | Samsung Ht-c650w 5.1 Home Theater System -...
Sound bar connections
I don't know if you have the original owners manual, so I am posting the pdf below. Everything that I have read indicates that your unit is a quality product. If your settings are correct per the manual, the manual states you should try resetting the unit per the instructions given on page 18. If that fails, I suggest you contact product support.
For Product Support Team Only:
1-800-229-1687
http://www.us.onkyo.com/
http://filedepot.onkyousa.com/Files/own_manuals/SN29401537A_LS-B50_UM_02_EN_130808_web.pdf
Dec 25, 2013 | Onkyo Audio Players & Recorders
Have a referb e1000 it still has someone elses network in it connects with no internet acsess
You will need to hold the reset button on the back for a good 30 seconds to reset the entire router. If that dosen't work please msg me back and we can try something else.
If my answer helped you today please give four thumbs up as thanks!
Sep 04, 2011 | Linksys Computers & Internet
My Samsung BDC6900XXA 3D BLUE RAY PLAYER DOSEN'T WORK, IT WAS WORKING GREAT THEN MY INTERNET WAS INTERRUPTED FOR 1 DAY THEN THE INTERNET WAS CONNECTED AND NOW THE BLUE RAY PLAYER TURNS ON BUT...
I have seen this happen before when an update went bad right in the middle of an Internet outage. If you bought this recently, try to return it for a replacement. Otherwise, you will have to contact Samsung's support line to see if there is a Factory hard reset.
Aug 25, 2011 | Samsung BDC6900 3D Bluray Disc Player
It wont read anything at all.
try unplugging it and then resetting it, you might have to format/restore all of the settings , but the best thing to do it RMA it in which youd be in the same spot as you would from format and start from scratch, hah its best to try 1st method if you dont want to wait. but if it dosen't work RMA is you best shot
Jul 18, 2011 | Sony Playstation 3 (PS3) Console
Iv'e purchased a 5 cup homemaker rice cooker but your leaflet dosen't explain how much rice or water ratio
I am sure that there is some official rice water ratio, but my method works for me.
1. Rinse the rice until no more "white" comes off of it and the water runs clear.
2. Let sit for one hour in water.
3. Drain water.
4. Add water to 1" over the top of rice and start in cooker.
5. Add 1 cup of water per day until rice is used up.
Jun 25, 2011 | Microwave Ovens
Chevy 2004 blazer ac stoped working abruptly and stops the engine if you turn on the ac could you just replace the clutch if that is what is defective? instead of the whole compressor and all the other...
I mworking on my blazer AC unit now . You have a problem with the compressor clutch or the compresser Its likely the clutch its supposed to cycle about 8 times per minute . So it goes on then off 8 times per munite this is normal . However if the clutch dosen't spin then the belt will drag on the clutch pulley this will stall the engine until the belt wares out but this will damage every part that the belt rides on . The water pump the alternator powersteering pump and belt tenisinor not to mention the belt .It sounds like your clutch is seized try not to run it until you can figure out why the clutch isn't spining
Jun 12, 2011 | 2004 Chevrolet Blazer
Uniden BC370CRS Base Scanner Logo
293 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
Greg Cann
Greg Cann
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
