Question about Microsoft Xbox 360 Console
Help ip adress failed
It says that my network adapter is wired then says ip adress failed whats going on i have know idea what to do next
  • xx-ram13-xx Jan 07, 2008
    it says that my network adapter is wired then says ip adress failed whats going on i have know idea what to do next
Your modem is not working properly contact your internet provider they will help you out
Posted on Jan 04, 2008
Hi, I bought a TP-Link TL-WA701ND (Wireless Lite N Access Point) today, and am having troubles getting it to work. The Quick Installation Quide gives directions for Windows operating systems XP and Vista...
You must setup manually your acces point. First go to control panel, under network and internet you'll find a task, view network status and tasks click on it and in next page go to change adapter settings, find local area connection and right click on it and go to properties, in next window highlight internet protocol tcp/ip then click on properties in next window click on use the folowing ip adress and write in ip adress box an ip from to at your choice in subnet mask box just leave (this apear when you click in these box). Now connect your acces point to the computer via network cable. Then open your internet browser and type in adress box and hit enter, a pop up will apear and ask for user name and password, write admin in both boxes user and password and hit enter, after that you will be able to manually configure your acces point and setup a name and password for your wireless network, change your user and password for acces your device. Good luck!
Mar 23, 2011 | ASI TPL WL TLWA701ND 150Mbps AP Wireless...
Hello i have d'link airplus g dwl g630 e2 5.0 network card in my other laptop.. it has drivers installed and it connects to network, but i cant get in internet.. it says " the connection has limited...
This happens when the wireless network card fails to get an IP address from the wireless router.
To get the router to issue your wireless network card with a new IP address, right click on the wireless card icon on the task bar and click Repair.
Mar 16, 2011 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
How do i change my ip adress on my ibm think pad
For that go to my network palces property or press windows key +R so you can see run type in run "ncpa.cpl" then press ok then you can see network adapter's property right click on your network adapter icon and click on property then click on tcp ip and change ip address .
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 20, 2010 | IBM ThinkPad T20 2647 Notebook
Error code 8002ad23
Hi Giles
You probably have your router connected to your modem, and a PC connected wired/wireless, and the ps3 connected wired/wireless.
1. First you need to start your ps3 system. Go to your network settings and select information. Write down your IP, Subnet mask, Standard Gateway, and the primary DNS.
2. Start your PC and go to your networks settings. Right click your network adapter, click properties. Select "Internet Protocol version 4 (TCP/IPv4). Click properties and type in manually the IP adress, Subnet mask, Standard gateway and DNS.
Then you click "Advanced" and then you click "WINS" then "Activate NetBIOS over TCP/IP". Save your settings and connect the ps3 to your network (should not make a difference if you do it wired or wirelessly)
Let me know if this helped and please do rate my solution.
Feb 06, 2010 | Sony Playstation 3 (PS3) Console
Ip adress keeps failing...?
Are you sure nothing else on the network your using has the Same IP Adress. If anything does, This IP will not work.
Jan 04, 2009 | Microsoft Xbox 360 Console
Wep address
Your wep adress? You mean your IP adress? Go to and that number is your IP adress. Enter that manually, and your XBox should be connected.
Jul 03, 2008 | Microsoft Wireless Network Adapter Xbox...
Network adaptor
try doing automatic ip instead of a static ip
Jun 21, 2008 | Microsoft Wireless Network Adapter Xbox...
Signing in
Connect it to your router with an ethernet cable.
Make sure the router is setup correctly to your modem, if you can connect all your devices by ethernet cable to the internet then it's set.
If you are using a wireless connection and if it asks for the WEP or WPA key, make sure that you are entering the correct encryption key. You may want to call your router manufacturer to know the correct key for the wireless connection. FYI, it will say that the wireless network is connected but it will still fail the IP Address.
If you have a wired connection and the IP Address or DNS failed, I suggest you to call your Internet Service Provider to check for the Internet connection and obtain these (static IP address, subnet mask, default gateway, primary DNS server and secondary DNS server). If your Internet is okay, enter the IP settings manually on the console (System > Network Settings > Edit Settings > IP settings).
That should work.
Feb 22, 2008 | Microsoft Xbox 360 Console
Get go to xbox live
For some reason everyone has the same problem buy the Xbox 360 wireless kit and should work but for now you might as well just wait untill get its fixed
Dec 30, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
54 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
