Acard Technology DVD±RW Burner
Problem for Acard Technology (ARS-2030LD) DVD±RW Burner
How do i copy a
By janahagene on Nov 04, 2009
how do i copy a disk
Comments:
Nov 04, 2009
- this is a dvd duplicator not something on my computer
Nov 04, 2009
- i have a acard duplicator and i can not get it to copy disks it keeps saying system over draft
Nov 04, 2009
- it is saying failure over draft am i supose to have a blank dvd-R or dvd+R
Nov 04, 2009
- Like how many minutes they both r
Nov 04, 2009
- when trying to copy a disk in my acard dvd duplicator does it matter if i use a dvd-R or a dvd+r
Solution #1
posted on Nov 04, 2009
Somewhat Helpful)
cq92
Rank: Wiz
Rating: 84%, 88 votes
If you are trying to copy a floppy disc use right click on what you want to copy, then locate where you want to put the file and right click again and paste.
If you want to copy a cd - data disc to your pc use the same procedure, right click, select location to store the info and right click, then paste.
You can also use the file menu to "select all" if there are a lot of files in windows explorer or my computer.
If you want to make a copy of a data disc to another cd, copy the files to your hard drive, then use your cd program to burn a new disc.
If you are trying to copy a cd- music disc - the songs must be "ripped" from the cd into either cd or wav format using a program such as Music Match Jukebox or similar with the "record" feature, or media player using the "rip" feature - this will place the tracks on your hard drive, then you can make a new cd from those tracks.
The same process is used for movie discs - except usually a DVD is used and a DVD burner and some movies are locked with copyright or region codes to prevent copying. Additionally - some software has the same lock placed on a few files to prevent making copied discs.
To use windows explorer (file manager) it is usually located in start/ programs/ accessories, the left pane will show the drives and folders in your pc, the right pane will show the contents of folders or drives, clicking the plus sign expands the folder to see the contents. To see files normally hidden, use the top menu tools/folderoptions/view and check the option show hidden files. There is also an option to see file extensions and also system files.
Was this helpful?
Yes
No
Solution #2
Somewhat Helpful)
fabioxx
Rank: Guru
Rating: 85%, 145 votes
How big is the source disk and how big is the destination disk? They should be the same size. what is the exact error you receive?
Was this helpful?
Yes
No
Solution #3
Somewhat Helpful)
charlymonty
Rank: Wiz
Rating: 82%, 255 votes
Before you Begin Make sure there is no program runing that has opened any file on the original disk. You cannot run the Disk Copy procedure if any file on the original or destination disks is in use by any program. For example, if you were editing a document in MS Word, saving to the disk in Drive A, and now want to copy it to another disk: FIRST quit the MS Word program, then execute the Disk Copy procedure. Caveat LectorThis Disk Copy procedure will make an exact copy of the original disk on the copy disk. It will completely overwrite the copy disk, replacing anything on it with the contents of the original (source) disk. That means that if there are any files on the copy (destination) disk before you begin, those files will be destroyed. You might want to take a look at the destination disk before beginning to be sure there's nothing on it you want to save. -------- Copying a Disk
  1. Double-Click on the My Computer icon on the Desktop. The My Computer window will open.
  2. In the My Computer Window, click once (not the usual double-click!) to select the icon for 31/2 Floppy A:
  3. Click on the File menu and select Copy Disk. The Copy Disk window will open onscreen.
  4. In the Copy Disk window you will see the option:Copy from 3 1/2 Floppy (A:) to 3 1/2 Floppy (A:)Click on the Start button.
  5. A new window will open prompting you to Insert the disk you want to copy from (source disk). Insert the disk and then click on the OK button. The program will begin "reading" the files from this original (source) disk. You can watch the progress in the little "progress bar" in the Copy Disk window.
  6. Once the original disk has been read into memory you'll be prompted toInsert the disk you want to copy to (destination disk)Now remove the original (source) disk from the drive and insert the copy (destination) disk into the drive. The click the OKbutton. You can watch the progress as the computer "writes" to the copy (destination) disk in the Progress bar in the Copy Disk window.
  7. When the copy is completed you'll see a new, small window popup that will report:The copy completed successfullyNow remove that copy (destination) disk. You are finished!
------- This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Was this helpful?
Yes
No
Popular Solutions for Acard Technology DVD±RW
Questions and Unsolved Problems for Acard Technology DVD±RW
Do you recommend Acard Technology (ARS-2030LD) DVD±RW Burner?
Answer
Answer
What does the message Target Overflow mean?
Answer
Acard Duplicator 1 to 1 Error Message Source Drive Not Ready .. Help
Describe your CD and DVD Burners problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top CD and DVD Burner Experts
Top Computer & Laptop Repairmen
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
