Posted on Jan 04, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Reset to english
Can't get my iPod Nano to reset to english.
  • Mi shell May 27, 2008
    My Ipod is Stuck on Engish and I can't get it to do anything?
Anonymous
Level 2:
Sergeant:
  • Expert 319 Answers
  • Posted on Jan 04, 2008
Anonymous
Expert
Level 2:
Sergeant:
Answers
319
Questions
Helped
133285
Points
888
Take it to a person who speaks spanish or whatever language you reset it to.
I just got a new ipod nano 8gb but it is in either chiness or japaness and I need to know how to get it to english
Press and hold down the menu button go down 8 items on the main menu then choose the last item which will be the reset settings then choose the first item and then select a language. Hope this helps.
I have a 8gb apple nano I by accident set the ipod on the wrong language I need to know how to change the language back to English
hold down the little black button and the pause button it should reset itself on factory settings.
How do u change the language back to english
If you have an iPod nano or Fifth Generation iPod (iPod with video):
  1. Scroll down to the last menu option but don't select it.
  2. Scroll up one menu item. This should be Settings.
  3. Press the Center (Select) button. This takes you to the Settings menu.
  4. Scroll down to the last menu option but don't select it; in English, this is the "Reset All Settings" option.
  5. Scroll up to the third menu item from the bottom one. This should be Language.
  6. Press the Center button to select Language.
  7. Select your preferred language from the list.
If this does not work.
Reset your iPod—Depending on how much you've used your iPod since selecting the language, simply resetting your iPod may cause it to forget the current language setting, enabling you to select a new one. See "How to Reset iPod" for instructions.
  • Connected. Eject before disconnecting
  • Sync in Progress. Please wait...
  • Do not disconnect
Note: When you reset your iPod, all your music and data files are saved, though you may need to reset some customized settings.
3helpful
Ipod in chinese dont know how to switch back to english.
If you accidentally set iPod nano to use a language you don’t understand
You can reset the language.
1 Press and hold Menu until the main menu appears.
2 Choose the sixth menu item (Settings).
3 Choose the last menu item (Reset Settings).
4 Choose the first item (Reset) and select a language.
Other iPod nano settings, such as song repeat, are also reset.
Note: If you added or removed items from the iPod nano main menu (see “Adding or
Removing Items on the Main Menu” on page 11) the Settings menu item may be in a
different place. If you can’t find the Reset Settings menu item, you can restore
iPod nano to its original state and choose a language. See “Updating and Restoring
iPod Software” on page 69.
Good Luck and Please Rate FixYa!
2helpful
How to get my language back to english
Select your language.
If you have an older iPod with color display (including iPod photo)
  1. Scroll to the fourth menu item in the screen and press the Center (Select) button. This takes you to the Settings menu.
  2. Scroll down to the last menu option but don't select it; in English, this is the "Reset All Settings" option.
  3. Scroll up to the third menu item from the bottom one. This should be Language.
  4. Press the Center button to select Language.
  5. Select your preferred language from the list.
If your iPod has a monochrome display (black and white):
  1. Scroll to the third menu item in the screen and press the Center (Select) button. This takes you to the Settings menu.
If the instructions above don't enable you to change the language on your iPod, try using the "Reset All Settings" option at the bottom of the Settings menu. If the Reset All Settings option does not work, you can restore your iPod back to factory condition and reselect the display language.
for more details just click the link below http://support.apple.com/kb/HT1824
rate the solution if it helps. thanks.
2answers
Change language to english
You have to reset your iPod. (Note: This is for the 3rd generation iPod Nano)
To reset iPod nano:
1 Toggle the Hold switch on and off (slide it to HOLD and then back again).
2 Press and hold the Menu and Center buttons for at least 6 seconds, until the Apple logo appears.
If iPod nano won’t turn on or respond
- Make sure the Hold switch isn’t set to HOLD.
- The iPod nano battery might need to be recharged. Connect iPod nano to your computer or to an Apple USB Power Adapter and let the battery recharge. Look for the lightning bolt icon on the iPod nano screen to verify that iPod nano is receiving a charge.
-Logan
I activated us english instead of uk english on my nano ipod 8gb - how do i rectify?
Reset the ipod in itunes.
Download the latest version of itunes from the itunes website and install it on your computer, once it is installed shut the itunes program.
Plug your ipod into your computer and itunes will open up automatically and pick up your ipod, got to your ipod settings and reset it. You will lose anything you have saved on your ipod, but can add music etc... into itunes then create a playlist and sync your ipod to your playlist.
I hope this helps
Language settins...
Reset, Retry, Restart, Reinstall, Restore
Remember these five basic suggestions if you have a problem with your iPod nano. If
one of the following doesn’t help, read on for solutions to specific problems.
â Reset your iPod nano. See “General Suggestions,” below.
â Retry with a different USB port if you cannot see iPod nano in iTunes.
â Restart your computer and make sure you have the latest software updates
installed.
â Reinstall iPod and iTunes software from the latest versions on the web.
â Restore your iPod nano. See “Updating and Restoring iPod Software” on page 50.
3answers
Change the language to chinese and can't get it back to english, Please HELP
Try doing Get Info on the Numbers program icon, open the Languages tab, and uncheck all boxes except English.
2answers
Can't put my ipod back in english
try to reset the i-pod.then if u have symbols then go to settings and change language... or buy a chinese to english book
 Grubhead
Grubhead
SmartAviator
SmartAviator
