Question about HP LaserJet 4p Printer
Misalignment messing up paper edge and printing
Hi, How are you?
My HP LaserJet 4P would mess up the edge of the paper as the paper moved throught the machine. Printed texts ended tilting to one side. The edge of the paper actually folded up about 3 mm (one eighth on an inch) at the tail end.
Could you advise what parts to fix/replace? Or, is it more economical to threw it away?
I put up this printer because I have an almost little-used toner cartridge in it and I have another never used cartridge on the shelf.
From1stState
  • 233 Answers
I would says check the fuser assembly for the folding the paper problem and the text tilting is a scanner/laser issue.
carefully check the paper path for anything blocking the way.
print a test page and open the lid when the paper is inside to stop it, inspect the paper to see if it's folded and also see the image on the paper to see if it's ok before reaching the fuser
hope this helps
Posted on Jan 06, 2008
My printer is squeezing paper edge while printing
HP printers have a side guide in the paper tray. That can be adjusted to be too tight or too slack by moving the edge guide out or in. Try making it just touching the edge of the paper.
Apr 22, 2014 | HP LaserJet 1200 Printer
How to do borderless printing on HP laserjet 1022n?
the hp 1022 is not capable of printing edge to edge for that matter very very VERY few can. the problem is that the printer needs to be able to move the paper through the machine without distorting the printed image and this requires a LEAD EDGE usually about 3-5mm edge to edge down the long side of the paper the printer is able to get quite close to edge at 2-3mm either side but NOT EDGE to EDGE the only real way of accomplishing true edge to edge is to overprint and trim the final page to size.e.g. print on A3 and cut to A4
Jan 29, 2014 | HP LaserJet 1022n Printer
Printer prints but crumples paper
I guess you have a roblem in your fuer assembly, replace it
Apr 07, 2010 | HP LaserJet 1300 Printer
I have a HP laserjet 4P. The print was coming out
You need to replace your transfer roller. Might as well do a complete maintenance kit.(Rollers, Fuser and Transfer Roller)
Nov 08, 2009 | HP LaserJet 4p Printer
Re HP Laserjet 4P after inserting envelope to print, upon giving PRINT command, printer will not print and indicates PAPER JAM. However, there is no real paper jam. No problem printing regular 8 1/2 x 11...
Most likely a bad pick up roller these machines will give a jam error if the paper or envelope is not picked up. Try cleaning the roll for the tray you are having the trouble with if the condition improves you have found the problem.
Hope this helps
Apr 19, 2009 | HP LaserJet 4 plus Printer
Laserjet 3015 is printing multiple pages on one sheet
exists special function in driver of the printer which quantifies pages of the document on one signet sheet. Sounds like "Multiple printing" you can manipulate or disactivate this function.
Mar 07, 2009 | HP LaserJet 3015 All-In-One Printer
Printing on my HP 4P Lazerjet produces shading on the left side
Most likely you need to put a transfer roller and a fuser in.
Feb 16, 2009 | HP LaserJet 4p Printer
HPLaserjet4P - printer service 50 -
A 50 Service error is a fuser error. Turn the printer off for 5 to 10 minutes, then turn it back on. If the error is still there, I think your going to need to make a service call you can try reseating the fuser, but be sure to let the fuser cool completely before touching it.
Good Luck the HP Laserjet 4p is a great printer.
Jan 28, 2009 | HP LaserJet 4 plus Printer
HP Laser Jet 4p printer problem - will not print continuously
Go to the printer setting's and make sure that the printer paper feed are not set into a Manual feed.
Thanks,
Feb 27, 2008 | HP LaserJet 4p Printer
Border page error
there is not any problem with your printer check the paper size only and adjust it
Sep 11, 2007 | HP LaserJet 1320 Printer
HP LaserJet 4p Printer Logo
127 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
