Question about LG WM1814CW Front Load Washer
De is displayed when i turn machine on
My lg machine keeps displaying de when i turn it on-is this an easily fixed common problem please
  • 489 Answers
Error code DE means door error problem.  Could be that the door switch doesn't sense the locking mechanism is working properly and may need to be replaced.  This will require a service call from a qualified LG tech to diagnose the problem.
Posted on Apr 27, 2008
Top load machine, been fine til today, will not move thru cycle, keeps turning itself of with 'de' notice, also has leaked some from inside machine
Troubleshooting LG Top-Loading Washing MachineDoor Error. The washing machine gives a flashing beeping DE error that the door (top loader) is still open while this is not the case. The small magnet has broken/fallen off. Attach a new magnet to the door (top loader) that will trigger that the door is now closed. Why dE Error is displayed on the panel of the Washing Machine
Why 'dE' Error is displayed on the panel of the Washing Machine? Last Update date : 2017.01.19
You may encounter a situation when your washing machine displays 'dE' error. This error appears when the door is not porperly locked.
If the Machine is displaying "dE" error, kindly check for the following :
? First and foremost the door must be properly closed.
? You can check the end of the drain hose is too low (Make sure the holder of drain hose in the back is intact).
? Also, you can check the end of the drain hose is submerged in water.
Jan 02, 2018 | Washing Machines
Where is located sensor of. Fuzzy logic t7517tepto
dE
Washing machine door detected as being open Door open error code can also be displayed as "dOE"
Very simple error, the fault code indicates that either the door is indeed open or that the door lock or door interlock mechanism cannot inform the electronics that the door is properly closed. LG door locks are known to and do commonly fail, the common one used in most LG washing machines and washer dryers can be found here with a link to a lower cost alternative part. However the door handle (can be found here) is also a common source of trouble and, if the catch doesn't engage into the lock properly you will get this fault code being displayed.
On non-display panel models this fault code is denoted by the light for the door lock being lit or flashing.
  • Check door is closed correctly and latched
  • Check door handle for damage or wear
  • Check door safety lock if inoperative replace door lock
  • Check door lock wiring
  • If there is a clicking sound once or twice when the Start/Pause button is pressed the main control board may be faulty
Dec 10, 2014 | Washing Machines
LG WM1814CW Front load Washer dE error? I get the dE error everytime I push the start button. The door wont open or close. I can hear the latch moving inside but nothing will happen. The "Door...
A dE error code indicates that the washer door was unable to lock. This can normally be resolved by performing a simple reset on the washing machine.
How to reset the washing machine:
1.
Press POWER to turn the washer off.
2.
Unplug the washer from the power outlet or turn the circuit breaker to the unit off.
3.
With the power disabled, press and hold the START/PAUSE button for 5 seconds.
4.
Plug the washer back in, or turn the circuit breaker back on.
5.
For more information about how to reset your specific model, please refer to the owner's manual.
Press in on the door firmly and select any cycle. The washer door should lock, and the cycle should begin without an error code appearing on the display. If the cycle does not begin and the dE code appears again, repair service is required.
Feb 03, 2018 | LG WM1814CW
We have LG FULLY AUTOMATIC WASHING MACHINE MODEL NO. 8018LS 7.0 kg PURCHASED 4-5 YEARS BACK. SUDDENLY TODAY WE GOT SOME PROBLEM IN WASHING MACHINE AS "dE" written on the top of the screen. please...
Door switch fault, either replace door switch required or maybe an adjustment of the switch. Push against door inwards when displaying dE and hold pushed in to see if it goes away to confirm switch problem
Aug 29, 2010 | LG Washing Machines
Getting a display of DE
DE refers to a Door Error.
Please check the following link for more detailing on this.The solution is also mentioned in the same link.
click for detailing on DE error code
To get the manual, here is the LG website, you just need to enter your location details and get the manual among the choice.(The reason for this is that few models are available only in some countries)
click here for LG Website
Good luck,Please do rate my solution and post comments.
Apr 19, 2009 | Washing Machines
Our machine's digital display reads 'dE' seconds after pressing start and nothing isour machine's digital display reads 'dE' seconds after pressing start and nothing is happening except for an awful b
The dE error means that the door switch has failed to "make" Either the door is not closed all the way, or the door switch needs to be replaced or adjusted.
Apr 18, 2009 | LG WM2487H Front Load Washer
You may have a door latch problem and it will need to be replaced.
Mar 12, 2008 | LG WM-1480FHD Front Load Washer
LG WM1814CW Front Load Washer Logo
752 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
