Question about Breadman TR875 Bread Maker
No beep upon button depressions
Also the machine does not register my button presses. The timer runs and that is about it.
It seems to start and run whatever cycle it feels like running. Is there something wrong with this machine? Should I return it? It was new for Christmas 2007.
I have seen a similar problem, and tracked down the cause: One of the buttons (the Down Arrow button) is stuck, and causes the timer to count down and for the system to not start. Once in a while I can wiggle the button enough to get it to stop, but since this is definitely a manufacturing defect I will be sending it back under warranty.
Posted on May 13, 2008
6ya staff
SOURCE:
Golds Gym 420 belt stop working but the rest is working like the incline and the console but the running belt is not working is there a button combination i can press to reset it ? it seems its just on...
Remove bottom motor hood. Is the red KLED lit on the controller? When you press start does it beep and does the timer start? No LED replace controller. No beep or timer start console keypad is bad.
Jul 13, 2016 | Exercise & Fitness
Bosch dryer beeps
Two Beeps on my Bosch WTE84100au Condensing Dryer means a thermal overload but also means one of the thermal sensors is faulty .... as if it is always on.
Open the door, pull out the lint catcher and clean around the silver probe (it's like a shiny 1/8" nail sticking into the cavity below the lint catcher). If it still doesn't work (and still 2 beeps), just flick it lightly a couple of times. If it still doesn't work, flick again from the other direction.
Mar 24, 2014 | Dryers
Cmos beep codes
do you know which bios your computer is running ?
AMI BIOS beep codes 1 beep - DRAM refresh failure
2 beeps - Parity Circuit Failure
3 beeps - Base 64K RAM failure
4 beeps - System Timer Failure
5 beeps - Processor Failure
6 beeps - Keyboard Controller / Gate A20 Failure
7 beeps - Virtual Mode Exception Error
8 beeps - Display Memory Read/Write Failure
9 beeps - ROM BIOS Checksum Failure
10 beeps - CMOS Shutdown Register Read/Write Error
Phoenix BIOS BEEP codes. 1-1-3 CMOS write/read failure.
1-1-4 BIOS ROM checksum error.
1-2-1 System timer failure. (Programmable Interval Timer PIT)
1-2-2 DMA (direct Memory Access) failure.
1-2-3 DMA page register failure.
1-3-1 RAM refresh failure.
1-3-3 64K RAM chip or data line failure.
1-3-4 64K RAM odd/even logic failure.
1-4-1 64K RAM address line failure.
1-4-2 64K RAM parity error.
2-?-? Any beep series starting with 2 beeps indicates a 64K RAM chip or data line error.
3-1-1 Master DMA register test.
3-1-2 Mslave DMA register failure.
3-1-3 Master interrupt mask register failure.
3-1-4 Slave interrupt mask register failure.
3-2-4 Keyboard controller failure.
3-3-4 Screen (video) memory failure.
3-4-1 Screen initialization failure.
3-4-2 Screen retrace failure.
4-2-1 Timer tick interrupt test failure.
4-2-2 Shutdown test failure.
4-2-4 Unexpected interrupt in protected mode.
4-3-1 RAM test failure above address 0FFFFh (64K +)
4-3-3 Interval timer channel 2 test failure.
4-3-4 Time of day clock failure.
4-4-1 Serial port test failure.
4-4-2 Parallel port test failure.
4-4-3 Math Co-processor failure.
BEEP codes may vary dependent upon the revision of BIOS. This list is for reference only
hope this helps
Oct 10, 2012 | Intel Mother Board S5520HCR (988889365963)...
Aquacycle 1000 will not operate the 30 minute short programme. Advice please
i think there might be some programming fault .
so set the timer again or
start pause button
after having selected the required programme press this button to start the machine the corressponding pilot light stop falshig.
to interrupt the programme which is running depress the start/ pause button the corresponding light start to flash.
to restart the programme from the point at which it was interupteed
press the start/puase bitton again.
Jan 14, 2012 | Washing Machines
I had continue beep sound when I turn on power. Can you help?
Beep sound indicates that the timer is finished and can be stopped by pressing start/stop button, however, it is not normal to hear continuous beep sound upon switching on the unit. Try to check if the timer button is not stuck and or check if you have programmed time.
May 12, 2011 | Star SWB7RB Waffle Maker
Code 88
Plug the pump in. You will see code 88 which is normal. Press and hold the down button for 2 seconds until you hear a short beep.Then press and hold the up button for anohter 2 seconds until you hear a short beep and the LED flashes 00. Using the up button set the time to run based on the size of the pool which you did not list. Tell me the size and I will tell you how many hours to set on the timer. You can download an owner's manual here: http://pr-rp.pmra-arla.gc.ca/PR_SOL/pr_web.ve1?p_ukid=5143
Jun 01, 2010 | Intex Automatic Salt Water System for ...
Kenmore elite smart sensor model 110.6506 wont run
Many different possibilities. Could be thermal fuse, timer / control, motor. Start switch, or door switch. Most likely need to call service unless you have means to troubleshoot and test parts.
Nov 03, 2017 | Kenmore Elite HE4 Electric Dryer
Sharp a/c-#AF-S85FX
The e1 code is operated by a timer which stops the machine every 720 hours of run time. There are 2 procedures to reset this.
1) unplug the machine. Hold down the power button while plugging it back in and waiting for a beep of about 5 seconds duration. Release the power button. Unplug the machine again. Resume trying to use it as an air conditioner.
2) unplug the machine. Hold down the Mode button while plugging it back in and waiting for a 3 second beep. Release the mode button. The machine will start. turn it off by pressing the power button. Resume trying to use the air conditioner.
If these do not work, the "clean filter timer" is broken and will require you to replace some parts.
(Aren't you glad there is a computer is almost everything?)
Jul 24, 2008 | Heating & Cooling
Noise
The top of the unit that covers the coffee beans has a plastic point that must depress a button on the main body of the unit when it closes to show the unit that the lid is closed properly. If this is broken (as was mine) I inserted the end of a piece of tooth pick replacing the plastic point in the lid and this now depresses the recessed button on the main unit. The beeper goes off and the on light comes on.
Jun 19, 2008 | Cuisinart Thermal DGB-600 Grinder
Cannot turn off alarm.
The machine will not run if the covers /for the coffee grinder, the filter basket and the machine itself) are not properly closed.
It will beep and stop running if it is turned on when one of the covers is open or if one is opened before the end of the cycle. The beeping will stop as soon as the cover is closed.
To start the machine again, press the ON button.
Hope this will help you.
/Mirran
May 09, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Breadman TR875 Bread Maker Logo
51 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Mike McBirney
Level 1 Expert
Irene Tulloch
kmciner
Level 1 Expert
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
