Question about Samsung SMH7178STD Microwave Oven
Samsung Over range Microwave
My microwave has begun to beep each morning starting from 2:00am -2:30am . When I check the unit the display has this on it --SE-- , Most of the buttons on the keypad will not work, I have unpluged the unit . It comes back on I reset the clock & everthing is fine , but about 20 minutes later the process starts again. I have found if I unplug the unit & just leave it for the rest of the night the next morning when I replug the unit in & set the time everything. works fine the rest of the day , However the problem starts back that evening again around 2:00am . Is th --SE-- a error code , What is causing this problem? Could it have anything to do with the change from day light saving time , since it seems to start each evening around 2:00am
The same error message "SE" just happened to my Samsung Microwave and it is less than 1 yr. old. I have tried unplugging it and waiting. It also happens at night. I am not sure what time since I don't feel like staying up watching the microwave break. Has a solution been found since my receipt has not been.
  • Samsung Master
  • 9,098 Answers
The -SE-error is a shorted keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jul 21, 2008
Mine just started today too. I am thinking of taking a ball bat to it. Samsung foriegn made piece of shit.
Posted on Jan 13, 2008
2 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Samsung Over range Microwave
This is really odd. I would first suspect a setting under "My Choice" (press "My Choice" then 1, 2, 3, or 4 and check settings.
Or maybe a failing sensor.
But overriding all of this is the fact that it happens at roughly the same time each day, which is why I go back to suspecting an odd setting. Nothing in the owner's manual refers to this.
So I would recommend contacting Samsung for assistance. 1-800-SAMSUNG (1-800-726-7864), or see http:WWW.SAMSUNGSUPPORT.COM
Posted on Nov 05, 2007
This morning my microwave began making 3 beeps every 3 minutes.! I only use it to reheat.
Try unplugging it for a minute, then plugging it back in and trying it again.
If you still need help, contact me. See my profile picture.
Mar 30, 2016 | Samsung SMH9151W 1.5 Cu. Ft....
Hi I have a Samsung SMH9187 micowave that is dead (no display, light, fan, mirowave).
Sounds like the main fuse blew. It's either near where the power cord enters the cabinet, or behind the control panel (if an over the range unit).
You may also have some type of failure in the high voltage circuit; based on your description of the symptoms.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Aug 16, 2014 | Samsung SMH9187ST Microwave Oven
What causes a Samsung Microwave exhaust fan to turn on by itself?
mine turned exhaust fan on automatically... i couldnt shut it off... had to unplug it.... no buttons worked.
Aug 29, 2012 | Samsung 1.8 Cu. Ft. Over-the-Range...
Samsung microwave displays 8888 beeps then 6666
how can i fix this problem i have an air conditioner whit the same problem and don t work please help me here are very hot
Jun 20, 2012 | Microwave Ovens
Samsung microwave displays press 1-4...
The SE indicates a short in the keypad membrane, but to cure this! the whole keypad control board should be changed if effort to resolve is decided, I would also suggest checking the pricing.
Apr 16, 2012 | Samsung SMH9187ST Microwave Oven
Countdown through oven's Power Levels
Check that particular outlet for a neutral ground
May 29, 2009 | Panasonic Microwave Ovens
Samsung Bake & Toast Microwave MT1066SB starts heating but shows
getting t-4 on clock display and random beeping<br /> cancelling and unplugging don't fix it<!-- from fixya rte -->
Jan 15, 2009 | Samsung MT1066SS Convection/Microwave Oven
Beeps every 30 seconds
Your oven has a 24 month parts and labor warranty. I would contact Danby:
Consumer Help Line
1-800-26-DANBY
(1-800-263-2629)
Hours of Operation:
Monday -- Thursday 8:30am - 5:00pm EST
Friday 8:30am - 4:00pm EST
Or you may e-mail Danby Service at service@danby.com
Jul 17, 2008 | Danby DMW119 Microwave Oven
BEEPING EVERY 30 SECONDS
Consumer Help Line
1-800-26-DANBY
(1-800-263-2629)
Hours of Operation:
I have the same "SE" problem. After reading this thread here, I realise it's likely the keypad problem, which explains the microwave's behaviour (no key was working).
So there were two possibilities. (1)keypad failure and (2) bad connection.
Obviously the easiest thing I could start with is to clean the connection. So I first take the cover off. Behind the keypad is a circuit board. In addition to a few connections between the circuit board and other parts of the microwave, there is a ribbon connecting the keypad to the circuit board.
Loose the plastic on the connection, pull the ribbon out from the socket. I then used spirit to clean the exposed copper connections. Put every thing back to place.
Voila, it's working again and we have been living happily ever after.....
Nov 04, 2007 | Samsung SMH7178STD Microwave Oven
Microwave Ovens Logo
776 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
