Question about ASUS AI Lifestylestyle M2N-SLI Deluxe (ASUM2NSLIDELUXE) Motherboard
Built a new Computer
I want to use Asus mother board and cpu. My application is studio recording. In future I may have video edit work too. So suggest me what should be my mother board and cpu.
    Sergeant:
    Champion:
  • 243 Answers
What cpu do you use just now? Is it a pcie or agp card that you have? Is the ram ddr or ddr2? What you have ram/graphics wise will effect the upgrade path if you wish to continue using them. How much are you looking to spend?
Posted on Jan 04, 2008
  • Graeme Fallows Jan 07, 2008
    Please rate my answer if it helped ? Cheers!
What mother board should is best for use on this video editing,engineering,and games with better graphics and can also work for more than 18 hours?
The best computer mainboard, would be either an AMD AM3 mainboard made by ASUS. For example ASUS Crosshair IV Formula or ASUS M4A88TD-V EVO/USB3. Or an Intel computer mainboard. ASUS Socket 1156/1155/1366.
Your Pentium Dual-Core E2180 2.0Ghz on the LGA775 socket is not good for Games or video.
The best thing to do is to purchase a new computer system.
Use either AMD Phenom 2 or Intel I5 or I7.
Use a good mainboard as above.
Use a good Graphics card, Nvidia 400 series.
Keep all the components running cool with a case that you like and has place for lots of 120mm or 140mm fans.
Use DDR3 RAM 1333MHz or higher.
Use Cooler Master or Corsair Power Supply.
If however you are wanting a good mainboard to be used with your Pentium Dual-Core E2180 2.0Ghz on the LGA775 socket then click here.
ASUS is very good, all these mainboard on the LGA775 socket are good, choose one that looks good to you and one that you can afford.
Thanking you kindly
damnor01
Feb 02, 2011 | Intel Cpu Pentium Dual-Core E2180 2.0Ghz...
Looking to get new mother board because it went on fire, old mother bd was asus P5VD1-X HAVE INTERL P-4 CHIP AND DDR 400 MEMORY THAT I WOULD LIKE TO KEEP USING WHAT MOTHER BOARD DO YOU SUGGEST
Better to purchase new mobo, cpu n memory. Bcoz the compatible Motherboard for your CPU/Memory is no longer available. If it is available, only from the dead stock or refurbished. Better to purchase new motherboard/cpu/memory
Sep 17, 2010 | VIA Asus P5VD1-X PT880 Ultra Chipset 1066...
I have asus board p5 -mv1 it was working good and after a period it's stop working .. when i checked the computer mother board and cpu and every thing could be the reason even cpu fan & power supply i...
If nothing has changed I would suspect the power on button has failed. You could order one online to test this theory and replace the defective unit. They don't last forever.
http://www.directron.com/atxswitch.html
Jun 12, 2009 | ASUS (S370L) Processor Board
Need to change mother board
WRONG ON THAT I HAVE ALL THE BOIS INFO YOU NEED.
WWW.lemig.umontreal.ca/bois/bois_sg.htm
www.ping.be/bois/numbers.shtml
www.allelec.com
email: mike@ttitech.com
www.unicore.com
go on line type in
update bois or upgrade bois
enter
typing in the bois name and date will tell you about any update or chacges and how to get the updates for free'
bois download drives my work also
rod
ps if you want mother information buy the new cpu magizine [ computer powers issue march 2009}
give you mother boards cpu cooling options cpu venders and option and more info check it out
rod
Feb 04, 2009 | AMD Asus A7V-ML Socket A MicroATX...
I want to upgrade cpu on mother board p4p800
*********** board supports upto 3.2 GHz+ P4 CPU
Dec 03, 2008 | ASUS P4P800-E Deluxe Motherboard
Problems with Intel D946GZIS Motherboard
Hi pbkajey, This Asus board will easily handle your 3.4GHz CPU & fully supports 1600/1333/1066/800 MHz FSB.
Suggest this motherboard:
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=4244469&SRCCODE=GOOGLEBASE&cm_mmc_o=TBBTkwCjCVyBpAgf%20mwzygtCjCVRqCjCVRq
The only catch is this board runs, DDR3 memory. Up to 16GB of Dual Channel memory.
Asus link for the P5Q3 MB:
http://usa.asus.com/products.aspx?l1=3&l2=11&l3=709&l4=0&model=2563&modelmenu=2
Review:
http://techreport.com/articles.x/14655
Asus comes with an impressive three year warranty. Most manufactures support 1 year only.
Here is another Asus board that will run your CPU & DDR2 memory:
http://usa.asus.com/products.aspx?l1=3&l2=11&l3=709&l4=0&model=2581&modelmenu=2
Same 3 year warranty. There are two boards that support the 945 chipset below:
http://www.asus.com/products.aspx?l1=3&l2=11&l3=707
Keep in mind you do not have to keep the 945 chipset. The newer boards still support 945 & better.
The choice is your's.
Good luck pbkajey!
More question? Post here.
Mike
Nov 19, 2008 | Intel D946GZIS Motherboard
Gateway Computer
CVI error is a visual interface error, most likely a graphics card built onto the syetm board. However the motherboards are no longer available but there are a number of ways to upgrade this pc if all else in in good order.Contact for further support
Oct 18, 2008 | Gateway (4000811) Motherboard
I don't have mother board cd
Hi, I am confused regarding the model of the Mother board
you have:
The P5S800-VM is an LGA775 socket mother-board for a
Pentium 4 CPU.
P4-515, on the other hand, does not return any hits on the
Asus web-site search.
I think your best solution is to contact ASUS /USA:
1-888-678-3688
and talk to customer support.
They will guide you in identifying the exact motherboard you
have, so you can download the driver set from their
support site.
BTW.
I think you computer performance is very unbalanced at 256 MB.
This is not nearly enough memory to run with such a fast CPU,
(2.93 Gigs), and your machine must be terribly disk bound:
1) When your operating system runs out of semiconductor
memory, it begins to thrash to disk, which is 10 million times
slower then RAM, making the fast CPU a total waste of
money.
2) For a normal machine running Windows and a 3Gig CPU
you should have at least 1 GB of RAM, preferably 2GB
(RAM is cheap these days)
But before I put my foot too deep into my mouth, I notice that
you are running FREEDOS, does that mean you are running
DOS only (No Windows ?) for some specialized application ?
Martin
Jul 20, 2008 | ASUS P5S800-VM Motherboard
M-Audio Delta 1010 PCI CARD
It has 8 mono inputs or 4 stereo pairs, which can be recorded in cubase or whatever sequencer at once.
Jun 17, 2008 | M-Audio Delta 1010 PCI CARD Sound Editing...
Second LAN not working
To get this issue fixed. you can update the Bios. However, you have to take care when you do this..... [ Correct version and Correct date need to be checked]. Good Luck.
Sep 01, 2007 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
ASUS AI Lifestylestyle M2N-SLI Deluxe (ASUM2NSLIDELUXE) Motherboard Logo
49 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
