Question about Kenmore 22422 Top Load Washer
What is the best way to winterize a standard large capacity washing machine?
  • 864 Answers
Turn off the water at the cold and hot taps. Disconnect the hoses from the taps and the washer and drain them. Lay the drain hose flat on the floor to drain it to a container. With the hoses disconnected and the drain hose flat, start the fill cycle (set to WARM) briefly (15 seconds) to open the inlet solenoid valves and allow water to drain from them. Start the rinse cycle to pump any residual water out of the tub and drain (15 seconds).
OR
Turn off water and disconnect inlet hoses as described above. Pour 1 gallon of RV anti-freeze (for potable water systems) into the tub. Start the rinse cycle just enough to start the drain so antifreeze goes through pump and into drain hose. Before using the washer again, run a small rinse through to flush out the anti-freeze.
Posted on Nov 04, 2009
  • 222 Answers
If the product will be exposed to sub-freezing temperatures, turn off the water supply to washer, disconnect fill hoses, drain them and reconnect. Remove the drain hose from the standpipe in the wall and place it into a shallow pan at floor level untill the water floe stops. Unplug unit and you are good to go.
If no sub-freezing temps are expected, turn off water supply. Turn on washer for a warm wash cycle for a few seconds to relieve the pressure in the hoses. Turn off machine and unplug it.
SOURCE:
Hello, what is the capacity of Kenmore washer 110.28803890 in kilograms? Thanks
As a rule of thumb, 12 pounds of laundry is appropriate for a standard capacity top load washer, 15-18 pounds for a front-load washer, and 20-22 pounds for an extra large capacity front load washer. 1 lb.is .4536 kg so 15*.4536 is 6. kg. 18*.4536 is 8.17 kg.
Mar 13, 2018 | Kenmore Washing Machines
Trying to figure out the washer capacity for model # 22622 100 from around 2002 or so
suggest you check with the manufacturer's website . model numbers do nothing for us
Aug 30, 2017 | Washing Machines
What is capacity in cubic foot?
  • How to Calculate the Capacity of a Washer Tub - About.com Home laundry.about.com > ... > Selecting a Clothes Washer 2016-04-14 · Video embedded · How to calculate the capacity of a washer tub ... your washing machine ... listed in cubic feet. A regular capacity machine is between 3.1 ...
  • Washer buying guide - CNET www.cnet.com > Appliances > Washing Machines 2013-09-12 · Washer buying guide. ... They have a smaller wash capacity, averaging at 1.5 cubic feet, ... What washing machine capacity do I need?
  • Washing machine capacity in cubic feet ... - Yahoo Answers https://answers.yahoo.com/question/index?qid=20121014130558AA2ph3V
    • RESOLVED
    • 3 POSTS
    • 2 TOTAL ANSWERS
    2012-10-14 · Washing machine capacity in cubic feet what does this mean? ... What does DOE stand for in regards to a washing machine's cubic feet?
  • Washing Maching Buying Guide - Warners Stellian ... www.warnersstellian.com/washer-buying-guide washer buying guide: ... Most conventional top load washers range between 3.2 and 3.5 cubic feet. ... The majority of washing machines are 27? wide, ...
  • What Should I Know About Washing Machine Capacity? www.wisegeek.org/what-should-i-know-about-washing-machine-capacity.htm What Should I Know About Washing Machine Capacity? ... A load of synthetic fleece sweaters will take up many cubic feet while not weighing as much.
  • What is the cubic foot capacity of my Kenmore washing ... www.shopyourway.com > Manage My Life > Questions 2009-09-21 · What is the cubic foot capacity of my Kenmore washing machine, model number 110.82984110? Report This by Manage My Life. September 21st, 2009.
  • Geeks On Home: What Is the Standard Cubic Feet for a ... www.geeksonhome.com/info_12199449_standard-cubic-feet-washer-dryer... What Is the Standard Cubic Feet for a Washer & Dryer?. ... What Is the Water Capacity for a Washing Machine? How to Measure Cubic Feet. How to Find the Capacity ...
  • Geeks On Home: Washing Machine Capacity Guide www.geeksonhome.com/info_12116692_washing-machine-capacity-guide.html Washing Machine Capacity Guide. Washing machines turned the chore of washing clothes by hand into an ... They typically have between 3 to 3.8 cubic feet of washing ...
  • May 04, 2016 | Washing Machines
    Maytag a212
    Looking for this answer too. Judging by your question's age my search might as well be for Atlantis. Anywho, in the first link below a user claims the capacity to be 16 gallons for standard (large) and 19 gallons for extra. I put this into Google and got 2.14 cf for 16 gal and 2.5 cf for 19 gal.
    http://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?48413
    https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&es_th=1&ie=UTF-8#q=gallons%20to%20cubic%20feet&es_th=1
    May the Force be with you.
    Now for some words for Google to find:
    Maytag A212 Capacity CF Cubic Feet Gallons Size Matt Damon
    Oct 03, 2013 | Washing Machines
    Hotpoint hswp1000m washer cycle fills with water for large capacity but when it goes to rinse it won't fill anymore than low capacity of water?
    It can be due to a faulty water level sensor which evidently is a pressure switch. If the diaphragm is damaged it will require a larger water level to achieve the said pressure to shut the inlet valve in all the cycles.
    Jan 12, 2013 | Hotpoint HSWP1000M 3.5 Cu. Ft. Capacity...
    I need to know the size of my Kennmore Washing machine. I have looked every where on it adn cannot find it. Model No:11082980820
    Large capacity 27 inch, pretty standard direct drive washer. Easy to repair parts are cheap. I have a few repair photos HERE
    If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
    Feb 16, 2010 | Washing Machines
    Washers overflows at start of large load capacity only
    that could be either your watervalve or timer id try valve first its cheaper
    May 20, 2009 | Maytag Washing Machines
    Are you happy with the Kenmore 800 4.0 cu.ft. top load washer?
    For large capacity, a front loader would be your best bet. An HE2 by Kenmore should be sufficient. If a toploader is overloaded, it's more likely to do damage. Also a Whirlpool Duet would work. Whirlpool makes Kenmore, so shop for the best price, (they are the same inside)
    Apr 15, 2009 | Kenmore 24032\24036 Top Load Washer
    Size of washer
    Size varies between manufactures, the biggest I have seen is the GE which is 3.5 cu ft, base your machine on your standard size load, ours is about 8lbs however I dont overload, I take large items quilts, comforters etc to a laundromat, its not worth breaking my machine over a comforter wash for $3.50 American.
    Go to Sears.com and look @ the washers available
    Jun 06, 2008 | Kenmore 22422 Top Load Washer
    Kenmore 22422 Top Load Washer Logo
    125 people viewed this question
    fordexpert
    Kristen Denison
    Kristen Denison
    Level 1 Expert
    Jim Chinnery
    Jim Chinnery
    Level 1 Expert
