Question about Sharp AR-207 Copier
U2 CODE FLASHING ON PANEL
WE PURCHASED NE TONER AND WHEN PUT NEW ONE IN COPIER WOULD NOT WORK AND WAS FLASHING U2 ON PANEL. PLEASE HELP. THX JIM
    President:
  • 4,402 Answers
U2 is usually a memory type issue, have you unplug and then plug back in after 1 hr.
Posted on Jan 04, 2008
Code erreur U2-40
U2-40, mostly appears in sharp copiers when you installing new toner cartridge.the reason of this code is faulty CRUM chip because of different type of toner manufacture .
you cane this problem by replace the chip in the new toner cartridge by the chip in old toner cartridge
- the chip is located in the rear toner cartridge -
I hope this help!
Feb 14, 2011 | Sharp AR-5316 Advanced Digital Imager...
Sharp a163 photocopier ero u2 40 and h4
U2 40 is a CRUM comunication error with the toner (wrong toner chip on toner cartridge or wrong toner cartridge) try a new toner.
H4 is a fuser trouble code. Check to make sure all conection are right, Theres a few posible problems for H4, power board, MCU board, thermistor, or broken heat lamp.
Aug 30, 2010 | Sharp AR-160 Copier
Sharp AR-M276 m affiche maintenance requise code:U2-40,rien ne marche.je rallumer à plusieurs reprise ça ne marche pas.que faire?
it is IC conector problem.pull out the cartridge and put it into the copier again.if the problem still exists change toner cartridge.
Aug 15, 2010 | Sharp AR-5316 Advanced Digital Imager...
U2-40 code
CLEAR THE ERROR
Enter SIM
# - * - C - * - 16 - START
Mar 31, 2010 | Sharp AR-M237 Copier
Solution for SHARP AR 5127 error U2-40 call for service
This means that the cartridge's sensor is miscommunicating with the copier memory thus the code U2 -40. You should clean the inner sensor connector and the toner sensor of the spilled toner by low blower. Perform this code ;# , interrupt , C, Interrupt keys in that order and press 16 then Print key and the code will be cleared.
Feb 02, 2010 | Sharp AR-5316 Advanced Digital Imager...
ERROR CODE U2-40: SHARP AR 5127
ERROR CODE U2-4 COULD BE RELATED TO THE MEMORY BATTERY BEING DEAD ON TEH MAIN BOSRD IF IT IS AN OLD MACHINE SO YOU COULD CHECK THSI OR REPLACE AND TRY WITH NEW
Jun 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
Error code U2 on a AR201 copier
To find out the sub code for the U2 error hold down the Start key. Below is a list of the errors:
U2-04 EEPROM serial communication error
U2-11 Counter check sum error
U2-12 Adjustment value check sum error (EEPROM)
U2-40 CRUM communication error
To clear the U2-40 error try pulling out the toner cartridge and firmly reinstalling it. If that doesn't work you must install a new toner cartridge. There is a CRUM chip on the cartridge that keeps up with how many impressions have been made with that cardridge. You cannot "refill" these cartridges without replacing the CRUM. This problem occurs frequently with remanufactured cartridges.
To clear other U2 errors you must enter simulation mode.
Perform the following procedure to enter the simulation mode.
Clear key - Interrupt key - "0" key - Interrupt key - 16 - Start key - Start key. The unit should reset.
Nov 11, 2008 | Sharp AR 201 Copier
U2-40 error etc.
U2 is a memory error. It's either the RAM or the ERPROM. A techincian has to look at it and determine which part it is and replace it. The copier won't run until it is fixed. It could be a loose memory board as well.
Sep 02, 2008 | Sharp AR-207 Copier
What's U2 code and method for solution
U2 can have several indications.
The most likely one is that the chip that is on the back of the toner cartridge is not seated properly or has failed.
Try with the machine off, removing and inserting the toner cartridge several times to clean the contacts, next step is to try a new toner cartridge.
There is also a connector on the back frame of the machine that may be dirty or going bad.
Jan 16, 2008 | Sharp AR-5316 Advanced Digital Imager...
U2-40
The code was not included among the Status Code Indicator RAPS. U2-40 is a Communication Error between the Main PWB and the CRUM on the Toner Cartridge (CRU).
Sounds like the toner cartridge is not seated or is defective.
What that message is saying is that the small chip on the back of the toner cartridge is not communication with the processor board.
Jan 10, 2008 | Sharp AR-160 Copier
Sharp AR-207 Copier Logo
97 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
