Question about Dewalt DC011 AM/FM Radio
Will not hold a preset station or time
Dewalt not abused. Plugged in AC outlet and radio must be set each time it is turned on. The fuse inside is good...checked that. Two AA batteries are good. Any ideas?
  • 1 more comment
  • lbr338 Feb 06, 2008
    mine has the same problem. where do you find the button battery?
  • dnlhaas Mar 01, 2008
    Every time I turn off radio, must reset station. Radio is always pluged in and has battery in charger. Will not hold preset stations either.
  • zjak Apr 29, 2008
    after five seconds I loose my display and turning off the radio I loose the memory
  • 4,102 Answers
Hi the only other problem it could be is it should have a button battery inside that keeps the memory with power whilst its not plugged into mains.
If it hasnt been used for while this might be flat or if is being used regular then the chances are you need this replacing let me know how you get n ill help you more the button battery is about the size of a bottle top it might have come loose or just not working but you need to remove the case to do this let me know how you get on ok
Posted on Jan 04, 2008
  • 313 Answers
It may required display board.
Posted on May 29, 2008
Lock ion a radio station
Ten FM and five AM radio stations may be independently set. After programming the buttons,
pressing 1, 2, 3, 4 or 5 will instantly change the frequency to the preset station.
1. Turn power on.
2. Set the radio to desired station (see Tune or Seek Function).
3. Press and hold one of the desired memory buttons (F). The station setting begins flashing in
the LCD display (G). Continue to hold the button down until the flashing stops. The memory
button is now set.
4. Repeat steps 2 and 3 to set the other memory buttons.
Please see the attached images for the figure options.
Oct 19, 2014 | Dewalt DCO11 Radio
Jbl radio A56840 loses station presets and no volume
Toyota vehicles have a fuse in the kick for the amp and sometimes there is located under the hood ... This is the switch turn on for the amp ... And 1 of the fuses is most likely the memory or constant power. B sure to check all fuses ... I do not have AllData pulled up . If the fuses are all good the amp or radio may be bad ... Or both ... Be sure to check all the fuses ... Many times I get clients that say allthe fuses are good and it is still the first thing I check ..Usually is a fuse ..Good Luck
Jan 27, 2014 | JBL Car Audio & Video
Have purchased a dewalt radio/charger through sears, was a close out where had no instruction for presetting channels 1-2-3-4 Not able to set, need instructions.
1. Select the Radio Station you want to save.
2. Press and hold the Memory button that you want that station on, 1, 2, 3, 4.
The display will flash the station number, when it stops flashing, the channel is set.
Oct 21, 2010 | Dewalt DC011 AM/FM Radio
How do you work the channle preset
Oct 20, 2010 | Dewalt DC011 AM/FM Radio
Clock is in military time mode. How do I reset to regular? Also I want to preset radio stations and I've lost my manual.
Here is your manual in PDF format:
To set AM/PM (12 hour) or Military (24 hour) time - With the system off, hold down Alarm Setup and press On/Off to switch between AM/PM (12 hour) and Military (24 hour) time formats.
To preset up to 6 AM and 6 FM stations - Use the Track/Tune buttons to find the desired station. Then, on the control panel only, hold down any Preset button until the preset number lights. The station is now preset to that number.
Dec 05, 2009 | Bose Wave Radio
Dewalt Radio won't hold presets or clock time
Replace the two AA batteries in the battery compartment.
Oct 07, 2009 | Dewalt DC011 AM/FM Radio
How do I set the clock and preset radio stations on a Pioneer fhp800bt Premier?
Usually, you need to have key on and radio off. press and hold function button till u see settings menu. Set radio stations by press and hold preset # while on station till beep or display blinks.
May 07, 2009 | Car Audio & Video
Setting the time
Setting Time
1 Press TITLE repeatedly until the time is displayed.
For details, see “Displaying the Text” (page 13)
2 Press and hold TITLE for at least 2 seconds while
The time indication will blink.
3 Turn the Rotary encoder to adjust the hours while
the time indication is blinking.
4 When the hour has been adjusted, press MODE.
5 Turn the Rotary encoder to adjust the minutes
while the time indication is blinking.
The time is automatically set 5 seconds after the minute
adjustment. The time can also be manually set by pressing TITLE.
• To synchronize the clock to another clock/watch or radio time
announcement, press and hold MODE for at least 2 seconds after
setting the “hour.” Minutes will reset to “00”. If the display shows
over “30” minutes when you do this, the time will advance one hour.
Listening to Radio
1 Press SOURCE/POWER until a radio frequency
appears on the display.
2 Press BAND repeatedly until the desired radio band
is displayed.
F1 (FM1) F2 (FM2) AM F1 (FM1)
3 Press TUNE to select the tuning mode.
DX SEEK (Distance mode) SEEK (Local mode)
OFF (Manual mode) DX SEEK
• The initial mode is Distance mode.
Distance mode:
Both strong and weak stations will be automatically tuned in
(Automatic Seek Tuning).
Local mode:
Only strong stations will be automatically tuned in (Automatic
Seek Tuning).
Manual mode:
The frequency is manually tuned in steps (Manual tuning).
4 Press or to tune in the desired station.
Holding down or will change the frequency
Manual Storing of Station Presets
1 Select the radio band and tune in a desired radio
station you wish to store in the preset memory.
2 Press and hold, for at least 2 seconds, any one of the
preset buttons (1 through 6) into which you wish
to store the station.
The selected station is stored.
The display shows the band, preset number and station
frequency memorized.
•You will need to start from set up or you will not be able to set the mins
Dec 31, 2008 | Alpine CDE-9852 CD Player
Radio presets on my toyota camry 1998 will not hold any more.
be sure when setting presets you hold the button down for at least 3 seconds to set the channel, if you are doing this correctly, you may have a blown back up fuse under the hood. there are 2 fuses for the radio one is marked radio and is inside the fuse pannel on the inside of the car the other is for memory back up and located in fuse box under hood may be marked B/U just check them all to be sure!
Nov 19, 2008 | Car Audio & Video
Dewalt DC011 AM/FM Radio Logo
359 people viewed this question
Top Dewalt Audio Players & Recorders Experts
Gyula Lacz
Rob Beech
Are you a Dewalt Audio Player and Recorder Expert? Answer questions, earn points and help others
