I am constantly experiencing the uL message that stops the wash cycle when washing any type of bedding. I try to rearrange the items but ultimately have to remove the items and wring the water out and restart the cycle. It is so frustrating.
we come across this a lot. its a few things that could go wrong but major things of the washer. 1st there is a service flash for the board. that means a new software for it and need to call kenmore or whirlpool see if your washer qualifies. 2nd there could of been a piece of clothing slipped through the tub and wrapped itself on the shaft where the tub needs to come out to remove the clothing. 3rd this is happenning a lot that the main shaft is warpt and need to replace outer tub to get that fix
Was this helpful?
Yes
No
Popular Solutions for Kenmore Elite Oasis? 27052 Top
Does anyone know what a f1 fault code means on a Kenmore Elite top load washing machine? If I unplug...
(More)
Does anyone know what a f1 fault code means on a Kenmore Elite top load washing machine? If I unplug it the fault goes away and it will wash one time. The next time I use it I have to repeat the same process.
Oasis 27072 The washer kept going off balanced and showing UL. I could maneuver things around and...
(More)
Oasis 27072 The washer kept going off balanced and showing UL. I could maneuver things around and get it to work eventually. Now the drum is leaning to the left and showing UL consistently.
The washer kept going off balanced and showing UL. I could maneuver things around and get it to work...
(More)
I'm getting an F51 error code all of the time when I use anything BUT the "Whitest Whites"...
(More)
I'm getting an F51 error code all of the time when I use anything BUT the "Whitest Whites" cycle. That is the only cycle that will allow me to complete a full cycle. Can I repair this myself?
I have a Elite Oasis HE Model 110.27062600. In almost every wash the load goes out of balance the...
(More)
I have a Elite Oasis HE Model 110.27062600. In almost every wash the load goes out of balance the machine bounces all over the place, you get a ul error code displayed, we rearrange the clothes, and all over again, every time with 12 min left in the cycle, after several times, it finally finishes the cycle, very frustrating, BTW, a part was replaced diue to a recall back in may of this year, HELP!
