Old JVC TV
We have been given an old (at least 13 years) JVC TV. The first time we switched it on it worked well for about 20 minutes but then cut out and went to stand by. After pressing a button to get it back onto the channel we were watching, we got sound but no picture, for about 30 seconds before it reverted back to standy by again. On subsequent days, we managed to get about 5 minutes of viewing and then the same thing happened. Any thoughts on what we should do next? Thank you. Happy new year.
label on back is torn which is why we have only a few details of model/serial
  • 556 Answers
SOURCE: color is gone in a sony kv-c2963e trinitron tv
as you say that color came back for 15 minutes then went off. this is a clear indication that there is a loose contact or pcb crack somewhere in color section only. if that happens to be ok then check 1 antena or cable socket loose 2 loose connector in color section 3 print open or crack near chroma signal processor. 4 loose near color control. 5 chroma ic night be defective. if you are not tech person take the help of tech.person.
Posted on Oct 02, 2007
  • 3 Answers
SOURCE: 52" Samsung DLP
It could also be the color wheel, it's been documented for DLP TVs to have problems with both the lamp and color wheel. For those with a screwdriver and ability to read online instructions, you can replace the color wheel yourself. I took out the guts of my Samsung HLR-5067W and found that the color wheel shattered, I'm anxiously awaiting my replacement.
Posted on May 26, 2008
SOURCE: SONY WEGA KV-32XL90E
Hallo, IC MCZ3001D is damage. Cost 30 Euro. Greatings from Germany
Posted on Oct 06, 2008
SOURCE: RCA f20580wn 20" TV about 20 years old
Hopefully you have the problem solved.
If not, the RCA plugs, listed as input 1 and 2 are shown on channel 91 and 92.
I recommend connecting the DVD to either input. Turn on the DVD. Then run the auto programming function of the TV. It will find and program the channel for the DVD. Then use the channel up or down on the remote you are currently using and you should find a working DVD.
Hope this helps.
Rcs97
Posted on Oct 25, 2008
SOURCE: TV keeps turning itself on and off, onto standby
I managed to find a local repair man who fixed the problem. He put in a new transformer.
Posted on Dec 05, 2008
I Have a 2year old JVC LT 24c340 HD which switches off after about 15 minutes , then after a minute or two the standby light comes I have reset the 'TV to factory mode but it still switches off
warranty requirements , on hidden defects.
no defects are expected within 4 years for just domestic use.
call your dealer , write to the importer, about the fault its not a JVC point to make products for only 2 years lifetime.
JVC LT 24HS340 Instructions Manual Page 2
Nov 18, 2017 | JVC Televison & Video
TV Turns off after several minutes ! needs to be off for several minutes before it can be turned back on !
Sounds like the Thermal safety cutoff switch is either faulty or it is working correctly and the printed circuit board is overheating. given that the TV is 12 years old it may be simply a build up of dust. If you are not confident in removing the units covers and giving it a clean yourself (unplug it from the wall socket first) then take it to a service technician. having said that, the cost of having it cleaned is probably more than the TV is worth given its age.
Apr 08, 2017 | Pioneer Televison & Video
Changed lamp green light comes tv plays for about 1 or 2 minutes tv goes blank red flashes 3 times.
Not 100% sure but I am currently looking into this. 2 things it might be which are most probable. I replaced my lamp a few years back with no issues. This time around I figured I'd be proactive and bought a new lamp as my current one was going dim. Not unusable but I could tell. Lamp arrived and I put it in. Started up, great! Then after a few minutes it shut down and the red LED would blink 3 times. I removed the lamp and replaced it after unplugging the tv and turned it on. This time it ran about 20 minutes and same thing! Tried a third time and had the same thing. So I put the old bulb back in, and this time it didn't even turn on! I removed it and with a flashlight looked in there. There are two safety switches. The first is a very small pressure switch at the base of where the bulb interfaces to the TV. That switch ensures the bulb housing is seated. Secondly there is a switch in the rear side where the second door with the lever lock is. When you rotate it the switch is engaged. I replaced the housing carefully and made sure everything was tightly seated. The tv has been on for about an hour now no issues with the old bulb.
I have two theories and am leaning toward the second one I will suggest. One is that the bulb is somehow overheating as it is newer and brighter, or is somehow defective. The other theory is that as the bulb heats up the switch might be getting dislodged. I am leaning towards this given that it is working with the old bulb. But I am not certain. Soon I will try the new bulb again and may even attempt to slightly bend the switch out a little so that it is easier to engage.
Jan 05, 2011 | Sony KDF46E2000 46" Projection HDTV
Technika 26'' lcd tv long time to warm up
the reason maybe a bad capacitor that is taking time to charge up to the nominal voltage. check for capacitors (electrolytic) in the power section (probably smps). it may appear bulgy than the others.
May 31, 2010 | Televison & Video
We have an old TVwhose picture cuts out every 5mins or so
Not a picture tube problem. Re tune the the TV by auto search or manual tuning.
Store your favorites later in your way.
May 03, 2010 | Televison & Video
KP53S35 when tv turned on picture was
You TV has a bad CRT, a red CRT by the sounds of it. This TV is rather old, perhaps 11-13 years of age? Your TV has given you many years of service and I do applaud you for the care you have given it and the TV for it’s reliable in your home. The trouble you face with a rear projection CRT set of this age is that you can’t just change 1 CRT tube and expect it to be reliable and produce a good picture. All 3 tubes should be replaced, as they have all aged the same. The lives of these tubes are only about 7 years. A tube is not any easy or inexpensive repair on any RPJ TV. When you are faced with the cost of 3 tubes, which may not even be available in the market place… You should consider retiring this old friend and keep the manufacture in mind as you make a new purchase.
Mar 14, 2010 | Televison & Video
Dec 01, 2008 | JVC AV-32D305 32" TV
AV-2053m
My problem is solved!!! I called my neighborhood TV repair shop. The technician suggested I check the Internal Speaker Switch on the back of the TV. And sure enough, I had accidentally move the switch to the OFF position while carrying it from one room to the other. Ahhhhhhhh!!!!!!!!!!!!! my 13 year old JVC is as good as new!!!!!
Aug 02, 2008 | JVC AV-32260 32" TV
I have this 20 year old JVC turntable and I'm not sure how to work it. I also have a 20 year old equalizer from AudioSource and I'm not so keen on exactly what it is and what it actually does. Please help...
the out or the output of your JVC turntable is going to input in the equalizer and the output of your equalizer is going to speaker then works fine try this....
Jun 20, 2008 | JVC Audio Players & Recorders
JVC TV-13143 13 in. TV/VCR
Its could be a fuse but highly unlikly. A surge will usually blow out the power supply, like short out the rectifiers,or the standby power supply. Its best to let a trained servicer look at the set. Good Luck
Aug 13, 2006 | JVC TV-13143 13 in. TV/VCR Combo
Televison & Video Logo
Top Televison & Video Experts
