Question about Brother MFC-845CW multi-function All-In-One InkJet Printer
"No Cartridge" error on Brother MFC-845cw
My brother has new ink cartridges and still does not recognize them in there- I have tried cleaning it, but it will not clean, it just sits there. HELP, I am about to throw it across the room!
  • stevebonse Feb 10, 2008
    where do i purchase a new cart at
  • 21 Answers
Something that has worked for some Brother owners to get cartridges recognised.
1. With your MFC powered up, open it up and remove the cartridge you are having a problem with, then close the MFC, leaving it powered up. It should report that there is no cartridge in the machine.
Still with the MFC powered up, open it up and reinsert the ink cartridge, then close the MFC. It should either ask if you have replaced a cartridge or go into its cleaning mode.
Answer "yes" to "have you replaced cartridge?" and it should either "print" or "clean" and then "print".
Posted on Nov 05, 2008
  • 832 Answers
Make sure that the claps are all secured (you can hear a click when it snapps into position).
Watch the lcd display: does it ask you something? If yes press the 1 button to compute the cart change.
If that doesnt work:
Did you use generic inc carts?
If yes, the led control is stained and has a short circuit. You need a new cart holder as a spare part.
If no and you have used original brother carts, take all carts out. Unplug machine from power outlet. wait a minute. replug to power. machine demands carts. reinstall carts and give answer to displayed questions.
Posted on Jan 04, 2008
Unable to clean 50 (brother MFC-845CW
Hi, to clean up brother MFC-845CW
Open the printer
Remove the ink cartridges from the print head.
Use cotton swabs dipped in hot water to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab.
Once finished, allow to dry and replace the cartridges
Try to print something now
You can also use the manual for help.
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002117/Mini3_MfcLcdW_UsaEngUsr_D.pdf
Jun 14, 2011 | Brother MFC-845CW InkJet Printer
My Brother MFC 440CN will not recognize a Brother
The usual obvious fix is to buy a new catridge, insert, power off machine, then switch back on to reset any sensors. But if the circuitry on the machine itself is faulty it wont fix it.
I used to own an MFC 260C. It had a perfectly good full ink catridge in it, that was working fine, until...it suddenly did not recognise the cartridge anymore.
I pulled the machine apart and found that 2 of the 4 sensors on the cct board at the back of the cartridge housing were loose. These sensors pass light through the exposed part of the cartridge to see if ink is there. So if these are faulty, you will never clear the "No Cartridge" or "Ink Empty..." or "Near Empty Ink ..." messages on the MFC260C and prbably other similar printers in the MFC range.
Why did they fail? Because the soldering on these sensors was poor quality.
I would never buy another Brother machine because of this, also because they design the machine to be totally useless unless all the ink ccartridges are full. Shame on you Brother, and kiss my *** for the $160 pile of junk I bought off you that was only on its second batch of cartridges (ie very little use)
Jan 23, 2010 | Brother Office Equipment & Supplies
Brother Mfc-845cw and Mfc-465cn both stopped printing Black about the same time. Using Non brother Ink. Tried cleaning, replacing carts, unpluging maching. how can I fix this.
the black ink that was used in the refilled cartridges was probably to thick for the nozzels on the head, you can try buying the original cartridges and then cleaning again, or check with the store you got these cartridges from as some of them offer a warranty
Nov 20, 2009 | Brother MFC-465CN InkJet Printer
Mfc 845 will not with black ink. The ink cartridge is new. Will print in color. I ran it thru the cleaning cycle. Only prints the top half of sentences.
This sounds like an alignment issue. Please refer to this support artilcle and follow the instructions given there to align the cartridge. You may have to reseat the cartridge, by carefully following these instructions. Make sure the lock release lever is firmly engaged. (clicks).
Otherwise, you have as mentioned cleaned the print head, though you could try cleaning again if the alignment doesn't correct the error. For other support help, please see here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Oct 09, 2009 | Brother MFC-845CW InkJet Printer
Brother mfc 240 c Will not recognize G&G Ink cartridge
try to clean the pinout of ur cartridge and of ur printer cartridge mount with acetone
Jun 08, 2009 | Brother MFC-5840CN All-In-One InkJet...
Black print won't work on Brother MFC-845CW
Open the case,i don't sure were the cartridge is located but i think is easy to you to find it.When you found it, wipe the botton part of your cartridge use soft clothe for cleaning.Look at mannual to locate the cartridge.
May 19, 2009 | Brother Multi-Function Center MFC-240C...
Brother mfc-410cn colour cartridge problem
There may be three problems here.
1.Not doubting your skills for one minute, nor wishing to offend you in any way, but did you remove the protection strip off of the Magenta ink cartridge? Sometimes we forget to do that.
2.Once a new ink catridge is installed, it's best to go to the Brother diagnostic tools section, and run a test. Sometimes an error code is kept, (Ink cartridge is empty), and the diagnostic tool checks this out. It then clears the error code, and 'recognizes' the new ink cartridge.
3.Ink may have dried, for the tiny little holes for the magenta ink cartridge, where it attaches to the body of the printer. Just this one ink cartridge. Suggest you don a pair of rubber dishwashing gloves. MFC-410cn -> Unplugged <- from the surge protector, use a clean, lint free, warm water, damp cloth, and wipe the holes for the ink cartridge, where it lines up with the printer body. This will be where you see that copper metal strip. (Or perhaps it's brass)
To clarify, you are cleaning the printer body. The area where the ink cartridge goes, and the metal strip. The ink passes from the ink cartridge, and goes through holes in the body of the printer. The metal strip is where these holes are located. Allow this area to dry. You may want to use a hair dryer set on low heat to speed the drying process up. Constantly move the hair dryer back and forth. Keep it about a finger length away.
Once you are satisfied this are is dry, reinsert the magenta ink cartridge. Plug the printer back into power. Advise waiting one minute, then turn the printer on.
Use the Brother diagnostic tool.
Should you not be able to find the Brother diagnostic tool, I suggest you go to Start>Hover your mouse cursor on All Programs>Go over to Brother>MFC-410cn>and to the Help section. The Help section, will tell you how to open the diagnostic tool.
Aug 19, 2008 | Brother MFC-410CN All-In-One InkJet...
Brother MFC 5840CNZ displays Ink Empty on CYAN when new cartridge is installed
Nov 08, 2007 | Brother MFC-5840CN All-In-One InkJet...
Mfc brother printer
Sep 13, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-845CW multi-function All-In-One InkJet Printer Logo
760 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
