Sounds like the lines may have dried paint in the or thay may be bad
I will tell you what the first problem is...YOU BOUGHT A WAGNER!
i know they are priced for the homeowner and marketed as such, but they are horribly built!
but heres some things that may help...
did you check that the tip was compleately cleared?
the pinhole helfway down the shaft is likely clogged, you need a tiny pin or needle to clean it.
2nd did you leave paint in it after using it?
all sprayers are very fickle and should be completly cleared though with at least water until you see no colorization in the water.
its best to run 'pump juice' through it as well to keep the parts lubricated.
also there should be small yellow filters in the handle of the gun, which will be caked with paint once again if you didnt run lots of water through it.
i have to take my CAMBELL HAUSFELD into the shop about every 100 gallons sparyed through....fickle creatures.
