This 3 color drop flashed when the color ink cartridge needs to be replaced.
Try to use a new color ink cartridge > If no go, call Kodak they will replace the color ink > If no go > Call Kodak and this time they will replace the printer
Remove all the cartridges and the paper from the printer...Power off the printer...unplugg the power cable from the back of the printer...while printer is unplugged from the power..press n hold the power button for atleast 60 seconds then release it..open the back door of the printer and look for any paper jam...remove paper from behind (if any) and roll the rollers in upward direction from behind..close the back door and connect the power cable to the printer and power on the printer..Look for the cartridge slots and clean it wid a lynt free cloth and the copper contacts of the cartridges as well...then insert only one cartridge (black or color) and close the cartridge door and check for any blinking lights on the printer...similarily repeat it with the other cartridge..by this u wud get to know if any cartridge is faulty? If u get blinking lights on the printer ...that means there is some problem,,,
Once you see the steady green light on the power..it means the printer is ready..You can also print a test page..."Press n Hold the power button down...while holding the power button down...either press "Down Arrow button" 4 Times OR "Red X button once"...then release the Power button to print the test print..
If it prints ..u r the master !!!
Best of luck
Remember if there is any blinking light,,the printer wont prin..
if the light blinks around the drops..it means there is cartridge issue and you may even replace the cartridges..make sure u remove the pink tape carefully before inserting the cartridges.
The light you describe is the ink light. When that light is blinking, try this.
Turn on the printer. Open the front cover and look at the carrier for the ink cartridges. There is a white arrow right above the latch for the color cartridge. Once the carrier stops moving, the white arrow should be pointing to a symbol which represents the problem (the reason the light is blinking.) Examples are low ink black, low ink color, sick black ( replace ) , sick color ( replace ).
IF you have just replaced your black cartridge, you might need to replace your color cartridge too. This printer will not work without both ink cartridges installed and full. You cant print with a full black and an empty color cartridge unfortunately, even if you only want to print black.
Red ink light flashes
One of the cartridges is low on ink. Check the message that appears on your screen to determine which cartridge is low or follow the instructions in Checking the Ink Supply. Make sure you have a replacement cartridge.
I hate Epson. Had problems with Stylus C82 and now my replacement Stylus C86 has given me nothing but trouble.
I've just replaced all four ink cartridges and now when I print I'm only getting blank pages. I uninstalled, reinstalled, and nothing is working. I even called Epson, twice, only to be routed to the Phillipines where neither person was very helpful, in fact, had a hard time understanding their English. So this is what I;m going to do. I'm taking this bloody Stylus C86 outside and smash it with a hammer..then I'm going to buy a HR Printer...and if anybody from Epson reads this...good luck...your products SUCK!!
Hi Greenhorn,
Your info is slightly conflicting - I think.
As I remember the C60 has just 2 LED's:
1 - Green for Power
2 - Red for Error
The third button - Cartridge exchange - has no LED
Now it is a while since I looked at a C60 and my brain leaks like a sieve, but that's the way I remember it and feel free to correct me if I'm wrong.
The error codes I remember are:
Printer status - Indicators - Priority
Power - Error
Power ON condition On -
Ink sequence Blink -
Ink Cartridge change mode Blink -
Data processing Blink -
Paper Out *1 - On
Paper jam condition *1 - On
Ink end (Black) *1 - On -> Blink
Ink level low (Black) - Blink-> Blink
Ink end (Color) *1 - On -> Blink2
Ink level low (Color) - Blink-> Blink2
Ink end (Black and Color) - On -> On
No Ink Cartridge (Black or Color) *1 - On
Maintenance request (Ink Overflow Countererror) *1 Alt Blink Alt Blink
Fatal error *1 Off On
Special setting Blink2 Blink2
