Question about AEG C41029G-M Dual Fuel (Electric and Gas) Kitchen Range
Electrical circuit Burning smell and fusing
This AEG range has been fine for 3 years from new. I have smelled the burning smell characteristic of circuit board burning out, but only when the oven is turned on. Yesterday the unit fused the the main house cooker circuit MCB. As this burning smell is continuing after resetting the MCB I would be grateful for any identification of the problem and any way to fix this.
  • 359 Answers
Very important !!!!!!! check the point of connection of this unit before next use
Posted on Dec 15, 2008
Instrument panel fuse keeps blowing, burning metal smell?
Some electrical short stay there, I suggest to check each electrical circuit that is connected to this fuse; check description or legend in the fuse label. With other details, we could send some electrical diagrams.
Apr 25, 2013 | 1997 Jeep Grand Cherokee
My Kennmore 79363 Gas Range/ Electric Oven electrical doesn't work. Started smelling electrical burning smell, tracked to oven. shut off breaker, smell stoped. Few hours later checked again after...
The person who installed the oven didn't do the connections up tight enough.
I would replace the breaker/power switch with a new one and trim back the wires if the burning is in the breaker. If on the rear of the oven, same applies with badly tightened connections.
If in doubt, call a qualified electrician. That will be better than having a fire!
Aug 06, 2017 | Kenmore 79363 Gas Kitchen Range
Bit of an electrical burning smell which may get worse on the drying cycle? also, how do you set the self diagnostics running?
Electrical burning is a bad sign. Unplug it and have it serviced! When you smell electrical burning that mean the resistance on the circuit has increased beyond the acceptable thresholds and the safety features such as ground fault, fuse and breakers are not operating. This is the cause of 100% of electrical fires! Take it seriously.
Jan 25, 2011 | Dishwashers
We purchased this product a month ago and it seems to be giving off a burning type of smell which we can smell both outside the vent and in the dryer itself. it seems to work fine
If it smells like an oily burn then it is just the oil burning off of the new parts in dryer, this is common. If it smells like electrical burning then call the manufacturer for repair. Could be a wire burning and if it is new it is covered under warranty.
Jun 14, 2010 | Whirlpool WED5800S Electric Dryer
My Model 2961 Eureka wont take power now?
Anytime that you smell that electrical burning smell on a vacuum cleaner, this is the motor going bad. There are two distinctive burning smells in fixing vacuum cleaners, the electrical burning smell which is the motor, and a rubber burning smell which is the belt.
The bagless vacuums cleaners in general, their motors last usually no more then 3-5 years. The motor in bagless vacuums work much harder then the motors in their bagged counterparts.
The motors in Eureka vacuums can range in price from $70-$120. If you can provide me with the exact model number on your vacuum cleaner (can be found on the bottom or the back of the machine on the sticker that also contains the serial number) I will be able to get you the part number, and price of the motor that's used in your vacuum.
It may be worth considering to just get a new vacuum cleaner at this point. If you'd like me to give you a personalized recommendation specifically for your unique cleaning needs, I'd be honored to do so. Please just let me know what types of floors you have mostly in the home and I'll be happy to share my knowledge of vacuum cleaners.
I hope this was helpful to you. If you found this helpful, please be sure to rate the repair helpful so other Fixya users that have this same problem can easily find the answer.
Thanks so much,
Chris J.
Apr 11, 2010 | Eureka 2961AVZ Bagless Upright Vacuum
Dualit lite 4 slice not working
It can be repaired. There is a short circuit inside may be of dust gathering on contacts or the contacts are worn out due to prolonged use thus touching the heating coil or body some where inside. Smell coming is definitely burning of wires inside. Open the toaster and you may be able to see the burning spot
Jan 09, 2010 | Dualit Lite 4 Slots 4-Slice Toaster
Whirlpool 24" built-in GU1200XTLBO dishwasher electrical smell
This may be the smell of Varnish used in motor winding. When we turn on the machine it gets heated a little bit resulting in a burning electrical smell.
Mar 11, 2009 | Whirlpool GU1200XTLS Stainless Steel...
Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
Smeg Oven electric burning smell
My Smeg cooker worked fine for 5 years. Then I noticed that the fan which stays on after you turn off the oven did not ever turn off, unless you switched the oven off at the fuse box. I think this is a fan that cools the oven down, but some bit of it is now broken because it doesn't realise that the oven has cooled down. It smells funny when you first turn it on, so I don't know if that is an electrical fault smell. Model possibly 70cm A420-5, but could be an earlier model (bought in April 2000). Is double oven with 4 rings on top, 70cm wide.
Mar 15, 2008 | Kitchen Ranges
AEG C41029G-M Dual Fuel (Electric and Gas) Kitchen Range Logo
553 people viewed this question
Top AEG Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you an AEG Kitchen Range Expert? Answer questions, earn points and help others
