Admiral AW22 Top Load Washer
Problem for Admiral AW22 Top Load Washer
Water leaking
By buckshar on Nov 04, 2009
Water leaking from bottom and tub off center
Solution #1
posted on Nov 04, 2009
Not Rated)
e-Guru
Rank: Wiz
Rating: 85%, 271 votes
Here are the steps you need to do to stop the contact leakage. Take the front Panel off or half off so you can see the inside of the machine ie: the drum, pulleys, belt, ect. At the bottom right or sometimes left is the water pump. Start your washer on its cycle and look at the pump to see if you see any water. Also check every other place that you are able to see. If it is the pump it is easy to change, a couple screws, the wiring connection plugs right into the pump, and a couple of clamps.
Thanks for contacting Fixya.com
Was this helpful?
Yes
No
Popular Solutions for Admiral AW22 Top Load Washer
Questions and Unsolved Problems for Admiral AW22 Top Load Washer
Do you recommend Admiral AW22 Top Load Washer?
Answer
Answer
When my washer goes into spin cycle it makes really loud noise and spins really slowly?? Can u tell... (More)
Answer
machine vibrates and moves all over the floor
Answer
Admiral Capacity Plus washing machine agitator sounds as if it's stripped after daughter ran full... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Admiral AW22 Top Load Washer:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14885
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
