Pull the cover off the unit with it running in a/c mode than touch the line going into the top of the outdoor coil it should be hot, if it is not than it may have developed a leak and now is very low or out of charge.
My RV roof top air conditioner has no power going throw the circuit board needing to replace the...
(More)
My RV roof top air conditioner has no power going throw the circuit board needing to replace the circuit board .
model 59516331G9 on the comfort control center digital screen will show temp set for a short time...
(More)
model 59516331G9 on the comfort control center digital screen will show temp set for a short time the show E-4 this goes back and forth fan will come and go off. The controls come on for furnace or coll but still show the same notes
a/c and furnace wont work.I have a duo therm, model #59516.531 on my toyhauler with a 3107541.009...
(More)
a/c and furnace wont work.I have a duo therm, model #59516.531 on my toyhauler with a 3107541.009 thermistat... The a/c-furnace switch when selected does nothing..cant even hear the relay board clicking.. but the fan works fine..High and low. I have checked the fuse in the relay box and circuit breakers on panel and on onan genny.. dont know of any more?
I have removed the interior bracket and outside I have removed the shroud. What is next? This is a...
(More)
I have removed the interior bracket and outside I have removed the shroud. What is next? This is a Duo therm roof top Penguin model
had loft conversion, problem on inside of picth roof where roof meets floor gets wet and patches...
(More)
had loft conversion, problem on inside of picth roof where roof meets floor gets wet and patches above velux windows and elsewhere appear, the builders did leave a ventilation gap inside the rafters before installing celotex, we have old type felt
