Home | Samsung | HP-R4252 42 in. HDTV Plasma Television | Sound but no picture.
Samsung HP-R4252 42 in. HDTV Plasma Television
Problem for Samsung HP-R4252 42 in. HDTV Plasma Television
By russell_jone on Nov 04, 2009
I have sound but no picture in any mode, only a black screen.
Best Solution
posted on Nov 04, 2009
Very Helpful)
mikeoldfield
Rank: Guru  Televisions & Videos  Expert
Rating: 97%, 23 votes
Problem is in either power supply or - my bet - the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
often that *needs* to be done in a service center as there are some adjustments to be made after replacement; don't know about this particular TV model, but it's a common thing for the plasma TVs.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Nov 06, 2009
Not Rated)
taylormad352
Rank: Apprentice  Televisions & Videos  Expert
Rating: 0%, 0 votes
Hey mikeoldfield, thanks for the response,but i could use a little more help with Viewsonic vpw425. I see a red lite that comes on which has alarm written next it also 2 green lites where one of them fades out.
Thanks again Cheers
Was this helpful?
Yes
No
Popular Solutions for Samsung HP-R4252 42 in. HDTV
Questions and Unsolved Problems for Samsung HP-R4252 42 in. HDTV
Do you recommend Samsung HP-R4252 42 in. HDTV Plasma Television?
Answer
Answer
I have a 4.5 inch wide mostly black vertical line on the front of my HP-R4252. Ideas?
Answer
plasma tv - starts with thin vertical lines that grow to black vertical bands and almost like a... (More)
Answer
plasma tv has lines up and down screen over the picture
Answer
i have a 46 inch samsung plasma lcd great tv now showing vertical line on left side of scrren comes... (More)
Answer
3/4 of the screen is lined and fuzzy, the remainder is fine?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Samsung HP-R4252 42 in. HDTV...:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
