Question about Epson Stylus 680 InkJet Color Printer
Epson CX5400 Hi. I have changed all the cartridges in this printer but the black cartridge gives me a message (Black ink cartridge error) if I remove the black cartridge it then tell me (no black ink cartridge) I replace the black cartridge and try the monitor software programme which tells me it cannot recognize the cartridge, this is not an Epson cartridge it?s a replacement from rubberfrog, which on the box it says 100% tested for Cx5400 plus others models. Do you know of a way round this or is it time for a new printer. Thanks for your help and time Regards Phillip.
  • Epson Master
  • 705 Answers
Nothing wrong with the printer. The rubbish cartridge you bought and replace it with one that works. Approx 30% of most compatible/refilled cartridges DO NOT WORK.
Not only that but they WILL block your print head nozzles eventually. Ever wonder why Epson do NOT make any flushing cartridges but almost every compatible "maker" does??
99% sure the cart is at fault. return it to where you bought it and get a swap.
Posted on Apr 02, 2008
6ya staff
SOURCE:
I have tried an ink cartridge that is not official Epson cartiridge - has worked fine for weeks now has decided that it has a error and it rejects this black cartridge. The other cartridges are Epson
Hi I had the same problem with a CX5400 printer scanner. My brother gave it to me because he'd put a compatible black cartridge in that was rejected. I tried compatible and genuine epson cartridges but no good. Still works as a scanner but wont print, not worth getting fixed.
Jul 27, 2011 | Epson Office Equipment & Supplies
PRINTING BLANK PAGE, BLACK INK CHANGED
It seems simple enough, but this is one of the most effective ways of fixing printer cartridge error. Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
To reattach the cartridge check the following steps :
turn on the lid of the printer and then remove the cartridge from the printer head.
Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report.
Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Oct 26, 2010 | Epson Stylus CX5400 All-In-One InkJet...
I changed the black ink cartridge and now it no longer prints using black ink.
please have at least 2 set of black ink cartridge to determine the problem where in print head area or ink cartridge itself. if two black ink cartridge inserted and still same problem you can now focus problem with the print head. change as possible.
Mar 31, 2010 | Epson Stylus CX5400 All-In-One InkJet...
Error message after replacing black ink cartridge
This happened to me twice, You can possibly have no ink in your cyan,magenta and yellow , you would then have to replace them to work the set. I had to do that and it worked =]
Jul 18, 2009 | Epson Stylus NX400 InkJet Printer
Black cartridge error
maybe the cartridge you buy is not same brand of your printer,, or try to remove printer driver using the ad and remove program, uninstall completely the driver and install gain
Jun 08, 2009 | Epson Stylus CX5400 All-In-One InkJet...
My Epson NX 400 is giving me this error message:Error B88/69/68 C
Try to run the ink pad reset utility software.
Please log on to epson.com. The software runs on win xp and win vista.
Mar 31, 2009 | Epson Stylus NX400 InkJet Printer
I have an epson stylus PHOTO RX500. I need to change the "black" ink cartridge but the ink carriage will not move into a position that will allow the top of the ink carriage to be lifted. When I push the...
Try unplugging the unit and then plugging it back in. When you first power it up, it should do an initial system check, which involves moving the print head. Unplug the unit the moment the print head is in a position to change the cartridge. I did this with my old Canon when I had the same problem and it worked. Hope it works for you too.
Feb 08, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
ERR 1C
Epson printers are known for this sort of thing. You left the printer too long without cartridges and the heads dried up. Buy a new printer and this time don't buy Epson.
Feb 21, 2007 | Epson Stylus Photo 915 InkJet Printer
Epson Stylus 680 InkJet Color Printer Logo
126 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
