Home | Zebra | TLP 2844-Z Thermal Label Printer | Printer keeps sto...
Zebra TLP 2844-Z Thermal Label Printer
Problem for Zebra TLP 2844-Z Thermal Label Printer
Printer keeps stopping halfway though run of
By info88911 on Nov 04, 2009
printer keeps stopping halfway though run of labels. Red light comes on and when pressed goes green reprints last label then a few more then stops again.
Solution #1
posted on Nov 17, 2009
Not Rated)
jiminyfixya
Rank: Wiz
Rating: 90%, 7 votes
Ensure that your ribbon is not popping off. Push ribbon onto sprockets This problem is usually caused by the ribbon protruding into the holes in the cardboard core. Use a sharp knife and cut away excess ribbon. You could verify this by removing the ribbon & re-printng a batch of labels (change driver settings to direct thermal mode)
Was this helpful?
Yes
No
Solution #2
posted on Nov 04, 2009
Not Rated)
Abrsvcs
Rank: Guru
Rating: 88%, 1809 votes
Usually this is a sensor problem. The printer is not recognizing that the labels are moving through. Remove the labels and blow out the interior with clean air. That may resolve the problem. Dust can accumulate on the sensors and cause this.
Please update this if that does not resolve the problem.
Thanks,
Dan
Was this helpful?
Yes
No
Popular Solutions for Zebra TLP 2844-Z Thermal Label
Questions and Unsolved Problems for Zebra TLP 2844-Z Thermal Label
Do you recommend Zebra TLP 2844-Z Thermal Label Printer?
Answer
Answer
Hi, I am having Zebra TLP 2844 barcode printer.I have installed the printer in my machine. I have... (More)
Answer
i have installed a zebra printer drivers correctly.. but once i send a test page its starts to blink... (More)
Answer
My ZPL2 command is: ^FO230,250^AF^FD&wz_descr&^FS where wz_descr is a variable with... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Zebra TLP 2844-Z Thermal Label...:
Top Printer Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
