Question about Dyson DC14 All floors Bagless Upright Cyclonic Vacuum
Filter doesn't look clean after rinsing
I washed my filter for the first time yesterday. It has been 6 months. The yellow bit with the white screens still looks dirty. And the water was never dirty or cloudy even, while running through it. Did I do something wrong? The new one looked so bright white compared to the one I was cleaning. I'm afraid the performance will start to suffer since it did seem to pick up better when I put the new one in.
Thanks for any help you can provide.
  • 328 Answers
It could well be that your Dyson is blocked elsewhere. Check the pipes, especially the feeder channels and the air way inspection channels on the Dyson as well as the main dirt channel after the rolling brush bar. Also brush clean the shrouds on the inner cyclones as these get notoriously clogged.
If the filter is washable it wont come up white like new unless you try a stain detergent like a pre stain remover. It would have to be heavily diluted as water is really the only way of cleaning a Dyson filter, but it also has to be of the washable type; Dyson produce a few filters, but some are not washable. EBay usually have good cheap replacements available but I'd check the first points first of all before filter replacement.
Posted on Jan 04, 2008
How to clean filter
The filter is usually replaced or washed.
Mar 03, 2015 | Filter Vacuums
How do you clean the HEPA filter on the Dyson DC14 Animal Vacuum
Hi there, it's Jack at Dyson.
DC14 has two filters, a pre-motor filter and a post-motor filter. Both are engineered to last the lifetime of the vacuum in normal use, but only the pre-motor filter requires maintenance.
We recommend washing the pre-motor filter at least once every 3-6 months using cold water without detergent, as shown in the video below. Always ensure it's completely dry before replacing it - this could take at least 12 hours.
The HEPA post-motor filter does not require any maintenance. We advise against attempting to wash or clean it in any way as this could cause damage. It's normal for the filter to discolour over time, as it's engineered to capture the carbon dust from the motor brushes. This will not affect performance.
I hope this helps, but if you'd like any further information you're welcome to contact our experts directly at 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Jul 11, 2014 | Dyson Slim DC18 All Floors HEPA Bagless...
If the filter is clogged would it quit working
Hi there! If the filter is clogged this will cause the vacuum to lose suction and possibly shut-off. Below are instructions to checking and cleaning your filters.
1. Remove the dirt cup. Twist off the dirt cup lid.
2. Remove the filter cartridge from dirt cup.
3. Separate the foam and cartridge filters. Wash foam filter under running. Allow 24 hours to air dry outside the vacuum.
4. Tap the excess dirt out of Hepa filter. Hepa filter may also be washed. Allow 24 hours to air dry.
5. Check the secondary filter by removing the filter cover from base. Rinse the foam filter under running water until it runs clear. Allow 24 hours to air dry.
6. The red baffle tube inside of the dirt cup is apart of the filtration of the vacuum and needs to be cleaned as well. Twist out the baffle tube by turning 1/4 turn clockwise. Remove any hair or debris wrapped around baffle tube. Baffle tube can be rinsed if needed. Allow to dry thoroughly.
If the filters are too dirty they may need to be replaced. With regular maintenance the filters should be replaced about once a year. Follow the links below to order replacement filters for your UH20020.
Primary Filter
Exhaust Foam Filter
Hope this helps!
Jun 12, 2014 | Hoover Nano Cyclonic Compact Bagless...
How to clean filter type f51
Hi! The F51 filter can be rinsed to clean. Hold the pleated filter under running water to rinse. Do not use any soap or detergent. Allow filter 24 hours to air dry before replacing in the vacuum. The foam filter can be washed the same way. The filter should be replaced about once a year. I have included a link where you may go to purchase a replacement filter if needed. Thanks!
F51 Filter
Jun 11, 2014 | Dirt Devil Vision Turbo W/Bonus Upright...
Resetting
Hello! The vacuum will reset itself, you only need to allow it time to cool off.This can take up to an hour. Overheating is usually caused by a clog or a filter that needs to be cleaned or replaced. Below are simple instructions for checking your vacuum for clogs.
7. Remove the hose from both ends. Use a broom stick to loosen and remove any clogs from the main hose.
8. Remove the bottom plate and the brushes as instructed in the owner's manual. Use a wooden spoon or something similar to gently break up and remove any clogs from the lower hose.
Hope this was helpful!
Primary Filter
Exhaust Foam Filter
Mar 23, 2014 | Hoover Nano Cyclonic Compact Bagless...
When you clean they dyson dc15 filter, should it look white. mine has not been cleaned in a long time and is completely gray
Hi Sherie,
It's normal for the filter to become discoloured after a period of use - this won't effect performance, although if you did want to purchase a replacement, you can do so by visiting www.dyson.com and clicking 'Parts'.
In normal use, the filter should be washed at least once every 3-6 months, as shown in the video below. Use cold water without detergent, and allow at least 12 hours for it to dry completely before replacing it.
If you have any further questions about using or maintaining your machine, please call us free on 0800 298 0298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Online Customer Support
Nov 25, 2011 | Dyson DC15 All Floors - The Ball Bagless...
How do I remove the filter to wash it?
Hi There,
Here's a step by step guide on how to clean the filter on your Dyson DC07.
Turn power off and unplug the machine.
unplug_us.gif Step 1
  • Press the release button and remove the filter housing from the machine.*
remove_filter_house.gif *The post-motor filter located under the clear bin should last the lifetime of the machine and does not need to be washed.
Step 2
  • Remove the filter from the housing. (Only the blue foam, yellow cage and white cloth should be washed.)
Step 3
  • Wash in cold water only. Please do not use detergent on the filter, or wash the filter in a dishwasher or in a washing machine.
  • Repeat the steps shown below until the water runs clear.
wash_filter.gif The filter should be washed at least once every 6 months.
  • Leave to dry in a warm place for 12 hours. DO NOT dry the filter inside a clothing dryer, hair dryer, microwave the filter, place the filter in an oven, or near a naked flame .
  • Ensure the filter is completely dry before replacing in the machine.
It is VERY important to make sure your filter is 100% completely dry before reinstalling it into the vacuum cleaner. Running the machine with a damp filter can cause permanent damage to your motor, or cyclone assembly.
What some people do is purchase an extra washable filter, this way they can easily swap filters when they need to be washed, preventing any wait time while the filter drys. Also after a few washing you'll notice the filter starting to deteriorate, sooner or later you'll want to replace the filter. Here's a link to the filter on our site if you'd like to get an extra one.
Dyson DC07 Replacement Filter Part No. 904979
I hope this helped you and answered your question. If this was able to answer you question, please be so kind and rate my repair helpful, or leave feedback for me. If you still have some questions, please feel free to use the comment field on the repair page, and I'll be more then happy to answer any follow up questions that you may have.
Thanks very much,
Chris Jones
GoVacuum.com
May 06, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My vaccume has little suction
Hello :
1: Check that the Dyson's brushbar knob is turned to the "Carpets" setting for vacuuming non-delicate and raised pile carpet. Vacuuming carpet on the "Bare floor" setting usually leaves a telltale single wheel mark on the pile, and pickup is severely limited.
2:Locate the removable filter on the side of the vacuum. It will be marked with a raised circular representation.
3:Press down on the release button with your thumb as you lift filter housing up and out
4:Examine the filter for debris. Wash the blue foam and yellow framed filter in cold water. (See Tips section.) Let dry for 12 hours. Do not wash the outer filter housing that snaps into the vacuum; simply wipe clean with a dry or slightly damp cloth. Replace the filter when completely dry.
5:Locate the airway inspection valve on the opposite side of the vacuum. Press the release button as you lift the valve up and away from the machine.
6:Remove any debris or clogs you find inside.
7:Use a soft cloth to clean up lighter debris and completely clear the airway valve.
8:Tip the Dyson vacuum over to find the U-bend at the back of the unit. Press the release button as you pull the U-bend down and away from the machine.
9:Inspect the U-bend and remove debris. Be sure to line up the release button as you snap the U-bend back into place.
10:Check all removable pieces to be sure they are attached properly and snapped correctly into place. The soleplate should be flush with the cleanerhead.
What you need for this :
  • Large slotted screwdriver
  • Scissors
  • Washcloth
  • Soft cleaning cloths
  • Household surface cleaner, safe for plastics
  • Crochet hook or similar long-handled tool
Warning :
Unplug the vacuum before doing any troubleshooting. Follow all manufacturer's instructions and warnings. The yellow encased filter and blue foam filter pad can be submerged and rinsed in cold water only. Do not use detergent. Do not wash or dry in dish or laundry machines. Do not dry in the oven or microwave.
PLEASE RATE !
Apr 23, 2010 | Bissell 3576 CleanView II Bagless Upright...
There is no suction to our Dyson animal (purple-approx 8 yrs old)
Hello bnsbryan :
  • Scissors
  • Washcloth
Warning :
PLEASE RATE !
Apr 22, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
How do I remove the washable filter to clean it on my Dyson bagless vacuum?
As you are looking down at the base of the machine (viewing from the front) you will notice a yellow button on the right side just inside of the the wheel area. push up the button to release the casing that holds the hepa filter and the spongy filter. You can see a diagram on your machine which shows this process. After you take the casing from the machine, the round housing which houses the 2 filters will come out of this casing as you pull it off. You can grab the spongy filter and pull it our of the casing. Rinse both filters as shown in diagrams on the side of the casing. Do not use soapy water, just warm water and squeeze out the spongy filter after each new soaking. Let the filters dry for 12 hours and then replace in your unit and enjoy the refurbished air movement. It does suggest that you clean these filters every 6 months.
Aug 07, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC14 All floors Bagless Upright Cyclonic Vacuum Logo
128 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
